Huawei Mate 20
Shadow79
Anyone using a Mate 20 with a Fitbit Versa?
Any issues at all?
I was using my Fibit Versa with my Mate 20. I believe the phone keep killing the Fitibit app in the background and notifications stopped coming in. Excluded Fitbit from auto memory management but I still not getting notifications once in a while.
lorettatay
Wats the recommended size n how long it took u to scan?
They recommend min 15cm and above. Took me less than 5 mins to scan that dog. But have been trying out diff sizes toys since last night till now haha.
Sent from HUAWEI Mate 20 Pro Emerald Green using GAGT
kirium76
Finally managed to get it working. The toy needs to be of the right size.
https://youtu.be/qa_MqD8UdJE
How come your dog only half bodied and also the dog face is like mutated one ah? Keke
Sent from Samsung SM-N950F using GAGT
Aikon
LOL... Yes that dog was a bit scary lah... Don't know what happened to the back half of the body 😝
flyingeagles
Got anyone went for inspection but failed the test?? Bringing mine to service centre tmr. Mine less than 5 days of use, since first day already got green bleed on left edge. Scared not as serious as some other people whole screen green, then they don't want exchange for me sia..
Sent from HUAWEI MATE 20 PRO using GAGT
Thanks, bro
SkyNinja
I stopped getting notifications on new sms messages received. Only after I open the messages then shocked to see many unread messages. Anyone knows how to fix it?
petricnah
If you are using the HW sms app should not have issues, 3rd party apps very likely will be stopped.
James Tang
Not a design flaw from my POV. That’s how they could pack a big battery and small size for the phone. Otherwise it would be a much bigger phone already.
Apart from the softer speakers, the phone really packs a punch in most aspects compared to other flagships for this year.
Like someone said before,'it's not a bug, it's a feature'...
Technically they have considered this and weighted in the pros and cons... I personally quite like this as I do not use the speakers much for my usual activities.... and maybe one day I go and do underwater testing HAHA
James Tang
I set up notification and so far both SMS and Whatsapp can be read at the lock screen.
James Tang
NO worries. If really have they should honor their promise
Huawei needs to make this work in order for them to stay as second largest on top of Apple and they knew this clearly. Their ambition is clear for all to see. So far their service has been good
So they will try not to screw this up. And I hope I am right on this.
James Tang
Any issues at all?
I am using. NO problem but take note:
1. If the Versa was paired with another phone before, disable that phone and restart versa for the phone to detect and pair
2. Syncing is much slower than what it was with iOS. Need to pull down the screen several times to initiate syncing, if it doesn't
MY sis-in-law is having the same problem as well and she is using P20 pro.
James Tang
This Article says its petty easy to create, but it does not look its very easy. I m just playing around with the default panda.
https://www.miscw.com/huawei-mate-20-pro-3d-scanning-camera-3d-live-maker-is-now-available-17752.html
Needs a lot of practice and trials.Getting the toy in the screen is already a problem cause not used to this haha....
The ad of course easy......... and live demo by that CEO guy also took some time, and probably after practiced many times already....
James Tang
this is creepy.... but at least it works... haha
Think the software can only recognise 'humaniod toys' based on the shape of the rendering....
Think my wife is going to kill me if we need to get larger toys to make this work....
