Huawei Mate 20
meekiatah
Huawei Mate 20 Series promotions at Sitex
Available at booth 5C07, Hall 5, 11am - 9pm, 22 - 25 Nov. Also available at Best Denki (6E07) and Harvey Norman (6D07) at Hall 6.
See that 20X is in. Currently using Max 3 now and am fine with it for entertainment. Should I go for 20X? Hmm...
leon0079
Does that mean i can use it as an extra charging adapter w/o the wireless pad? I been planning to buy extra charging adapter and selling away the wireless pad.
Sent from HUAWEI LYA-L29 using GAGT
Yes it is. I have 3 sets of the 40W adaptor now! Get a new set from exchanged set, retained the old set and one more from the wireless charger
Sent from Huawei Mate 20 Pro using GAGT
Horace Bin
Overheard one malysian staff in amk hp store says mate 20X will be selling w/o gift sets at local dealer stores for around 1K tag, don't know how true it is.
Abyssal.Xuan
Yes!! Like what Leon0079 says below, it's usable!
Can keep the wireless set, just use the charger and cable!
Or if you want, can sell the wireless set then buy a charging set :s13: :s13:
sajokj
Any one using UAG monarch or plasma with the Tempered glass from mobile hardware?
Does the TG pop out.
Planning to buy UAG Case.
athenodorus
Yes... it can customise to any device on the spot. Will go try tml... today my M20P will be delivered to me... :s12:
I can’t seem to find it there leh.
Edit: found. At a corner zzz. Doesn’t feel smooth. No oleophobic coating at all.
lorettatay
I'm not using tg from mobile hw but I'm using uag monarch with wwp tg. So far so good.
Sent from HUAWEI Mate 20 Pro Emerald Green using GAGT
sgbsgb
thank you sir for the info
Abyssal.Xuan
Those with exotic colours or simply like clear cases but are worried, I'd recommend the OTTER BOX symmetry case! Clear and solid feeling.
No I am not sponsored but I've been eyeing it (sorry UAG case).
I think got some prices up on carousell at $49 or something.
Am not from any store :s13:
Hopefully they fit with the different TGSP!
gavthang
just got my m20p today... just checking if i can auto save all camera shots in the memory card like samsung?
