summersky1986
- Jun 23, 2006
Really dulan the tried 3 TGSP and in display fingerprint didn't work.. later going casefactorie get the glue zeelot.. hopefully can get this over with
as shared by another mate earlier, pull down is lock. push up is clear from memory
I saw the hicare comes with 1 three screen replacement.
Why not just use naked till need to replace?
I bought if from Spigen Qoo10 store. It's around 36 per piece, it has thin black borders around through. It works with Spigen Neo Hybird and the official clear cases. Other cases, I am not sure.
No need screen protector la. Me and my wife and friend all nv use screen protector
I am also thinking the same. TGSP gives a lot of problems with fingerprint to work.
Tiagong need glue types in order for fingerprint to work.. Luckily I got refunded for all the Huawei TGSP.. 3 pieces total..![]()
tips to note as well.. redo fingerprint setup after applied tpsp.. it gets better after awhile so probably need some monitoring.Tiagong need glue types in order for fingerprint to work.. Luckily I got refunded for all the Huawei TGSP.. 3 pieces total..![]()
Anyone facing an issue with blur photos taken with the Mate20 Pro? Quite disappointed that most of my photos taken (of people) came out to be blur in good indoor lighting..
It works with other cases, I am using a baseus case. But for the fingerprint, its a hit or miss... now I am waiting for the whitestone dome TGSP for M20pro.
I'm currently using liquid crystal with RWM smaller sized tempered glass. No popping up issues.Anyone using the Spigen Crystal Case for the Mate 20 Pro with Red White's Full Adhesive Tempered glass with no popping up issues?
Sent from Samsung SM-N950F using GAGT
