Huawei Mate 20
AyuReady
Ya depend on the modes used. Some need to hold as it taking a longer exposure/mtiple exposure
Try turning off the AI. And just use the basic mode should be sharp and fast.
U need to hold awhile especially in portrait mode .after taking it says hold steady something like that.
I sometimes also blur
JayBeeLwashere
Nova launcher now ln sale for $0.90. But does using it with this phone have any issues?
Sent from HUAWEI LYA-L29 using GAGT
bystander1965
I have been using Nova prime for many years. No problem with any phone I have had so far, including current m20p.
One thing to note though is that some HW widgets need native HW framework. So they may not work with other launchers, Nova included. But then this is not a unique problem with HW phones I think.
Audiology93
One of the issue is not being able to place the clock widget on home screen.
Sent from HUAWEI Mate 20 using GAGT
KeYoKe
Even samsung or lg, their widgets also doesnt work with third party launchers
bystander1965
Ya. I vaguely remember I had problems with other phones on the widgets. But I don't use native widgets other than clock and calendar. And there are tonnes of clock/calendar widgets in the app store.
everdomdom
How was the quality of rwm tempered glass?
Recommended ? The pricing cheaper than zeelot right. does m20p comes with pre installed screeen protector?
I'm currently using liquid crystal with RWM smaller sized tempered glass. No popping up issues.
Sent from Samsung SM-N950F using GAGT
Geros_Peters
Mate 20 Pro does not come pre-installed with the film screen protector from factory. Usually red white mobile screen protector quality is pretty alright. Nothing to worry about actually.
RestInPepperoni
this time for mate 20 pro is quite bad, quality issues, the first few batch was good then they cut cost the new one is bad
twinklingstars
hi everyone.. im planning to get the m20p to replace my 2 year old xiaomi redmi note 3.. should i get it now, or should i get it at the next IT show in march, for the freebies?
Audiology93
March sure cheaper, but don't get from it show. Most likely retail price with "freebies". Cheaper to just get from Street shop w/o of the freebies. If really wan the freebies, can get from caoousell at a much cheaper price.
lumpyme
Must be careful too though, on carousel lol were selling the mate 20 for 720 - 850
So those selling at 720 seemed like the cheapest but on qoo10 I found a seller for 700, brand new set too
