Huawei Mate 20
mosprockett
Anyone here managed to install prime now on your phone?
Mine doesn't show in play store.
If search on Google and click the link, it says not compatible for device
Posted from PCWX using LYA-L29
friedapple
Hi guys, newbie here. In a dilemma whether to get the new samsung note 9 or the mate 20 pro. I read reviews that speakers wise, samsung note 9 wins but my question is how are the mate 20 pro's audio quality with bluetooth earphones? My mate 9 audio quality is pretty decent now. Thanks!
XiHamKueyTiao
totally no "white edges" on your new TG ?
Don't seem like have?
How come sounds like you got forced into saying these. :s8:
Maybe sounds overly positive, that's why. Or the way I type sounds like paid review :s13: Really not forced, how can they force anyway? More likely to report them trying to force if they did. Fixing the f-ed up SP is something they should do if they want to keep a good reputation anyway. I also didn't change the original posts about the screwed up SP, which weren't positive, just added update only.
This new one so far so good. If I didn't remember wrongly, the box says "Zeelot" brand, not sure mine or the previous customer's. Will report back if any problem arises. No problem so far other than possible incompatibility with cases. If I press hard near the top edge with my Spigen Rugged Armor on, I can see the SP start coming out a bit, release pressure then ok already.
maur_james
May I know for Mate20X users which brand/model car holder do you use? My Ottie cannot fit the phone with new casing on.
pilico
Guys, is there anyway to restore app data from rooted phone to m20p, including apps not from playstore?
Just got a twilight version for $900🤭🤭
Now manually download app😅
Guys, the google password autofill doesnt work for all app with m20p?
I try to hold for the autofill to popup but nth happen, autp signin only work for some app only.
thorsten139
ordered this phone from singtel, they are giving out the wireless charging pad also.
quick question, does it only come with regular earphones or are they giving the wireless buds?
ordered the mate 20 pro
pilico
Really? i see alot people buying from singtel no wireless charger sia.
Normal type c earbud
thorsten139
Free Gifts
HUAWEI WIRELESS CHARGER C60 Free
think so, i ordered under CIS. they running a good promo now.
only paid 50 bucks for the phone after the discounts
$200 OFF CIS RECONTRACT SIGN-UPS -$200.00
$88 OFF CIS HANDSET W DATA X 3 -$88.00
$30 OFF CIS SMARTPHONES -$30.00
PholkLorr
do you all use master ai? Sometimes i find it useful but other times i wanna take a quick pic but the master ai will take 1 second to detect something. Or it likes to auto portrait mode humans.
PholkLorr
alphacool
Ordered one with the CARBOT brand through EZBUY, claim to support up to 10.5cm width phones. Still waiting for it to arrive in Singapore. 2 in 1, has arm with suction, and aircon vent attachment.
friedapple
Free Gifts
Wah nice! What plan are you recontracted on though? The mid tier plan?
