Huawei Mate 20
veyonce
Anyone has good to recommendation for privacy screen protector that works with fingerprint sensors?
Currently using this 华为p20钢化膜p20pro水凝膜mate20pro全屏覆盖p20p防指纹mate20抗蓝光原装全包无白边原厂手机保护贴膜超薄软 https://detail.tmall.com/item.htm?id=567411349762&spm=a1z09.2.0.0.26ef2e8dHh2SPF&_u=mmamtg01adc
The fingerprint is working so far... It's a soft film that covers all the edges.
I bought the privacy screen but have yet to use. 华为mate20pro钢化防窥膜mate20防偷窥全屏覆盖抗蓝光mate20X手机贴膜前后防偷看刚化保护玻璃mete全包边pr0
https://detail.tmall.com/item.htm?id=580655951820&spm=a1z09.2.0.0.26ef2e8dHh2SPF&_u=mmamtg021d9
pawn_king
The inclusion of the wide angle which double up as macro lens as it can focus very near far far greatly exceed p20 pro's monochrome capability.
The dxo score is only for photo quality but photo taking is much more than the photo quality but overall usability and mate20 can take wider photos and macroshots compared to p20 pro which both cannot do makes p20 pro loses alot .
somehow p20p sub-scores for "zoom" and "bokeh" higher than m20p :s11:
friedapple
Can you share with us your reviews after trying the privacy screen one? Tried finding one with privacy on taobao but seems like there are issues cos of the curved screen.
sajokj
I just plug n play only. Can enable Aptx ? Need to ?
Edit : just found this : under developer option. But my Aptx is grey out
Finally Managed to enable Aptx, Here is How it worked,
To make sure the earbuds supports APTX I connected the Funcl AI earbuds to my One+ 6T and there I was able to get Aptx, then I reconnected back to my M20 Pro, then the APTX started working. Now Music Audio quality is really Great.
coolhirako
Great.
Sad i have no other phone to activate it lol
alphacool
I'm worried about using the aircon vent to hold the phone, it's quite heavy.
So far no problems, in fact aircon vent holder uses a hook to secure to the vent, if it drops the entire aircon vent would drop out. As compared to suction disc, depends on the quality of the suction, if it gives way, the entire phone and holder falls.
pilico
Yeah and some used ones going for around 850.
Lol this phone is getting cheaper and cheaper😂
Anyone encounter the screen identify your finger touch as knucle?
It affect me when i play games and scrolling, i dont know whether this is software or hardware issue==
The app assistant also quite useless.
I thought it will disable kuncle function but it doesnt work==
pilico
Where u all find m20 pro at 920+++? Carou?
Search dude. Need to hsve fast hand and leg.
Search mate 20 pro, change the setting to recent.
Browse every 2hours till you find the price you are looking for.
marxace
Anybody using the 256gb 8 gb version of mate 20 pro which can be bought from malaysia?
ahtionginsg
I read from somewhere news that mate 20 pro has an update that enables HDR playback for Netflix. This update seems not.
Sent from HUAWEI LYA-L29 using GAGT
