Huawei Mate 20
pilico
Finally they fix the gesture haha
Now i just hope they can tweak night mode to be on par with google nightsight 😂
FinalTidus
I think you should stick with xiaomi first if security issues and malicious spyware is or concern.
Nowadays like a lot of news about huawei.
Not saying their are not safe but who knows haha
All mobile companies do collect our data, just dont know what they do with it.
True. Yes my concern is about the security and malicious software as I do keep a lot of personal info on my phone.
I always knew that Chinese phones in general collect a lot of data, but Huawei is particularly notorious and infamous for it with spyware and stealing of info. Xiaomi may be doing the same thing but I think they are that little bit more cautious and give consumers more option in disabling data collection.
Ok then. I will stick to Xiaomi as advised. :) Thanks!
pilico
What gesture issue initially?
Sent from HUAWEI LYA-L29 using GAGT
I dont know whether this affext nova launcher users only or all users.
The swipe up and hold to access recent task was buggy for me and when in recent task, you cant switch to the app on the left or right without swiping the app to the center.
Swipe up to home is smoother too.
Doesnt really affect the usage but still good to see it fixed.
symbiote28
ooh this is a bug? i'm using buzz launcher and it's like that too. i thought it's actually how it's supposed to be.
Vaan55
Nice! Glad to see it's fixed.
Currently updating my phone now, on M1 sim
bystander1965
Ya that the one on left/right cannot be recalled was v irritating to me. But I didn't even notice the fix till u mentioned. Thanks.
One strange thing though. I am also on M1 but I got 183 update on 25th?
h3r090
Originally Posted by plustwo:
repeat again, this sp works perfectly and only $2:
https://www.ebay.com/itm/For-Huawei-...r/123496512752
if you want the uv glue one, this one is about $5:
https://www.aliexpress.com/item/For-...949657432.html
Received the UV glue one, it was a mess and ruined two of the protectors, waiting to receive the non uv glue ones
And on M1, still no update
Agree, tried the UV one today and it does not fit Spigen Rugged Armour case at all. Suitable for people not using it with any cases.
Vaan55
I had problems applying, either not enough glue or too much glue :s13::s13::s13:
Waiting for the non glue version to arrive
Abyssal.Xuan
Start user, received update today! Update already then they tell me my SD card corrupted. Had to reformat )':
bellick
Huawei software still very buggy. If you have work profile, after every update they'll ask you to key in lock screen passcode to re-enable work profile but it'll keep showing error despite keying in the right code. Gotta remove the entire work profile and add back again.........
eciloP
Hi guys. Just changed from Xperia XZ Premium to Mate 20 Pro. So far find that my battery is depleting quite fast. Mine maybe a couple of minutes of usage will drop 1% even only on light usage such as web browsing, replying to whatsapp etc. Screen is at fhd+ only and location off. Nothing much in background.
Yankun
Hi, may I know how do you remove the entire work profile? I tried and it still goes back to keying lock screen password which also keep showing error.
What i did is uninstall all the work profile apps and set up again to get it working
_DeS__
Recently my M20Pro will have this indian male speaking out on loudspeaker randomly. Anyone facing this issue?
coolhirako
My m20p keep getting notification of wechat at background
It say wechat is running
Touch for more information or stop the app
After scroll down , the msg will disappear in few second. Don't know whats going on leh
DiCaprio
Happened to me also before (even though I disable wechat running in background). If no ATBs are constantly messaging you, i think it should be fixed with the 183 update
Sent from Tomorrowland using GAGT
ahtionginsg
183 here but didn't fix. I didn't have this problem when I bought the phone. Only after an software update then it started to appear.
