Huawei Mate 20
DiCaprio
183 here but didn't fix. I didn't have this problem when I bought the phone. Only after an software update then it started to appear.
Sent from HUAWEI LYA-L29 using GAGT
Hmm then it looks like it's still patchy.. 183 does solve the multi tasking bug when switching between apps so that's good
Sent from Tomorrowland using GAGT
Ryrian
Huawei mate 20 pro
Singtel awarded me 200$ off handset when re-contracting, thinking of buying huawei mate 20 pro but does the current batch still have the issue of gluegate? or should i just get samsung note 9 instead
knave
This is a wechat bug I think. Since they did a interface revamp within the past couple of weeks
Posted from PCWX using HMA-L29
FreshMaker
hi guys just got my mate 20 pro..
is there any convenient way to transfer my data (pics, vids, contacts etc) from my samsung s7e to my huawei, preferably without the need to use a computer...?
thanks
apostrophe
thanks
Pics/vids: Google Photos
Contacts: Google
SMS: I don't know. Anyone?
ahtionginsg
I did an update to wechat from setting/about/check for updares to 7.0.3. Seems the wechat still running notification disappeared.
bystander1965
thanks
As said use huawei's phone clone. M20P has it pre-installed. Go playstore to dw for your Samsung.
But I suspect because pie uses a much stricter permission policy you might find after transfer your social media apps may not give notifications etc.
I used phone clone and my wa telegram etc were not set up with the right permissions and they didn't ask for them either.
bellick
Hi, may I know how do you remove the entire work profile? I tried and it still goes back to keying lock screen password which also keep showing error.
What i did is uninstall all the work profile apps and set up again to get it working
Settings > users and accounts > scroll all the way down and remove work profile
Extremme
Sorry guys. I got mate 20 Pro today. Was trying to set up Dbs Sg app but I cannot seem to see the setup of faceid option under setting, personalization. Was there a bug?
I am not using fingerprint as I am using privacy screen.
hermoso
Hi guys.. thinking of getting mate 20 and mate 20x
Any idea where can I get cheapest? TIA
