Huawei Mate 20
KeYoKe
Loving my twilight
Posted from PCWX using LYA-L29
GReddy G9 RS
Anyone switch from Mate 20 to Mate 20X? How's the battery life n performance?
Sent from HUAWEI MATE 20 using GAGT
1982-1994
Very good question.
Though the two are using the same CPU, m20x lasts longer. But m20 can clock higher SOT.
gerald27
I switched from 20X to 20 .... did not regret my choice :)
I think the battery don't drop as fast as when I was using 20X
Changed also because I didn't like the screen on the 20X
GReddy G9 RS
So Mate 20 is better except for the larger screen on Mate 20X.
chenaz
Lesson learned. Huawei is not water resistant s.
I bring my mate 20 pro to swimming. Didn't really put into the water. But only dip less than 5 times in the water. And now the bottom speaker is like a bit distorted sound. Hopefully when it dries up and everything will be ok.
update
oh yea. whole phone only about 10 to 15 cm in the water.
the water Resistance is too weak
Blueberrytea
Cos LCD more energy efficient...bigger screen will drain bigger battery too about the same...unless super big like 5500mah above
coolhirako
update
So your mate20p speaker cui liao ?
Blueberrytea
update
Probably faulty unit...bring in for service or exchange lol ip68
chenaz
yes. now cui. sound quality became so bad.
let you all know after it dries up.
i watched the videos and confidently bring to the pool. everything works fine except for the speaker. the videos that i watched all nv test the speaker after putting in the water.
chenaz
donno water indicator got change color not. if no(how to check?) then can send in for repair.
if the speaker didnt spoiled. i can confidently bring it to the pool next time.
too bad ,huawei failed me
jlekssp
Your phone confirm faulty... Not only swimming, I wash my phone at least once a week and working perfectly well...
athenodorus
have u waited long enough for it to dry first anot.
