Huawei Mate 20
aallzz
Does it have the black border? Face ID still works? Fingerprint still works?
I am looking for a compatible screen protector that does fit my UAG Monarch and Otterbox clear case. Fingerprint should work. Any recommendations?
Tried the mocoli tempered glass and it is good. Almost full coverage with spigen liquid crystal
KeYoKe
undefined HardwareZone Forums app
All still works. Yes have black borders, some cutoffs at the corners of screen but doesnt bother me as it is one of the better one i see. Otterbox symmetry can fit the zeelot loca glue tempered glass. That is the full clear one, but is at 49 bucks though
cheery
Hey guys.
Not sure if you encountered the same issue with your Mate20.
Normal use of Toggle app, ie watching on the phone is fine.
Problem comes when casting to Smart tv, for example my Sony Android Smart Tv.
After casting, if phone goes off screen, it will hang or ask to close. Then I'm unable to do any controls to the video on Toggle unless I close the app and try to launch the app again.
Then the cycle continues.
My old HTC E9 and my new spare phone Xiaomi Max 3 does not have this issue. Casting and controls in Toggle App after some time still works.
KeYoKe
Is the battery really that good
Am at 24 hour, 61 percent left, 3h15min sot. Pixel 3 xl should left less then 50 percent by now as i hit 6.5 hrs tops for that only
usage: social media, whatsapp (video call, message), phone calls
KeYoKe
Got mine from GW Mobile at Sim Lim Square and it works with Otterbox Symmetry.
I think otterbox cases can fit any tempered glass even the one i am using. So can consider zeelot, gwmobile (but some say they did a messy job) and the mocoli (not loca based one which i am using)
swaku24
Am at 11 hours with 28% left... Social media, streaming videos... How do you all get so much juice...
KeYoKe
I nt much apps. And i got off notifications for some of the apps. Thats all. I never go set the app launch thing all this. Let the AI ownself handle
cheery
Hey guys.
Nobody use Toggle app's casting function?
