Huawei Mate 20
cheery
Anyone else running Toggle app and casting to your Smart Tv?
After trying the App launch settings to Manual and the Battery optimization setting, Toggle still hangs and asked to close after video is casted on to the Tv.
(This happens when Mate 20 screen goes off after 30 secs or switch app and come back to Toggle...)
Even the Lock function also wont let the controls of that video stays. Have to sort of restart Casting though video is still on TV playing.
Anyone?
Thanks.
workedmw
sibei sian, i installed a $50 liquid screen protector, works nicely with finger print all. then i go put spigen rugged armor, next day onwards the sides of the screen protector came off slowly.
omg pissed off. any screen protectors that works for fingerprint and wont come off when used with spigen rugged armor?
Zapper1819
I also got similar issue using spigen... I use tape to tape the side to prevent it from coming out.lol
KeYoKe
Spigen case well known to lift loca glue tempered glass. U can try the mocoli tempered glass i posted a few pages back. It fits my spigen liquid crystal and it should fit your rugged armor too as liquid crystal has a thicker case lip compared to rugged armor
hongwan
Yes it's similar to mine. I have a BOE screen as well. But in that picture, it looked wider. Mine is not that wide but still very visible with white background.
If it's the glue gate issue, it most likely will spread, and I think the green would be slightly different.
If you are really concern, you can always try to exchange it. But to be honest, if it's just a thin line on the side, I bet they would just brush it off as normal.
thanks, got a 1-1 exchange..
new set looks much better, at least no color shift, still have refraction due to curved screen.
jackycar
Using spigen rugged armour here. Did a UV glass at NEX Benoi Mobile for $30. Cutting of glass is smaller and fits perfectly
JayBeeLwashere
May i know how to screen record with sound? I notice that when i screen record a video I'm watching the result has no sound
Sent from HUAWEI LYA-L29 using GAGT
Audiology93
You can't record audio using screen recorder app due to android's restriction.
https://forums.androidcentral.com/ask-question/885732-why-doesnt-android-allow-recording-apps-record-internal-audio.html
Sent from HUAWEI Mate 20 using GAGT
Watadoo
Are the LG screen still given for the 1-1 exchange?
Mine has the gluegate issue too. But I am concerned that I might get another LG screen that is prone to gluegate. Then would waste money on screen protector again.
Blueberrytea
Since it's a known issue I believe the exchange unit would be a boe 1...but u should check with Huawei for confirmation before heading down
pilico
I remember got 1 app allow you to record internal sound but you have to buy their earpiece to do that
workedmw
hi bro thanks for recommendation. does it work with the in-screen fingerprint? so far any bubbles?
chenaz
