Huawei Mate 20
kenchi
Cool tips bro thanks
Yes can lock phone using Huawei lock widget.
I play both pubg mobile and MLBB no issue. Both can play smoothly. 5ghz wifi also working well.
Sent from HUAWEI Mate 20 using GAGT
teoph04
Wondering if it's still worth getting this phone or should I go for P30 Pro
Sent from HUAWEI ALP-L29 using GAGT
kryptonit3
unless you really need that high detail zoom I don't see what major differences in both... besides extra 2 GB ram and pie 9.1..
Sent from HUAWEI LYA-L29 using GAGT
kenchi
ZergRush
Need download Device info hw app. It will show. Iirc there is no way to tell unless you unbox it
mackie8
Decided to get mate 20 non pro to replace my pocophone...
Mate 20 prices now are pretty good deal
$600-650
Guys where did u get your tempered glass?
Flat screen should be easier to find right?
bystander1965
I got the same update on Mate 20 pro
Yup, you are right. I got this 232 on my M20P today also.
So the last update with March security patch was a fake? A typo? Just to shut the customers off? :p
Looks like their update QA/QC control is not very good. This is not the first time the description runs ahead of itself.
Anyway, I have music stop coming out of the headphone jack after a song ends randomly. Have to unplug and plug.
Also, sometimes, the fp touch area refuses to show up no matter how and where I touch the display. After a while when the phone is happy it will show up. :s22:
These 2 problems show up after an update some time back.
molecule
$600-650
Nowadays I just get cheap tgsp fr AliExpress or TB. Works fine.
