Huawei Mate 20
mackie8
Guys is this better than pocophone f1?
Im planning to sell my poco for this since now price is quite reasonable...
Im mainly using for gaming and i want better camera...
pilico
For camera, i will take pixel .
I find the software for this phone camera isnt that amazing. But of course if you use pro mode only, this phone is for you.
I find that the AI kinda useless and auto mode isnt as good as pixel or iphone.
If you want to use 40mp, you cant zoom or use wide angle. You have to manually change the mp to be able to use the zoom funtion.
Only if they able to automatically change by itself, it will be great.
When using the phone, sometimes it detect my finger as knuckle, causing my phone to screenshot in the middle of game. ( the only way to stop this is to disable the knuckle gesture feature.
Audiology93
Definitely better than poco in every way, except for the nano SD.
Sent from HUAWEI Mate 20 using GAGT
pilico
Do you guys know any app or method to create long exposure with live photos, like iphone Without using skily water mode?
ZergRush
Any other way to lock the phone, other than pressing the power button?
Decided on mate 20 pro after seeing the price of p30 pro at $1250.
Got it @ $880 with wireless charger
pilico
I am using nova launcher. I set it to lock when i double tap on empty slot.
You can try using tasker. Shake to lock and many more ways
KeYoKe
Got a widget screen lock which u can add to ur app icon at home screen to lock
batniss
Anyway to 4G load balance between 2 SIM cards for data?
Especially when one is down the other automatically take over. Right now i have to manually select which to have data
Audiology93
Use nova launcher then set double tap to lock screen, or use the lock screen widget if you're using EMUI launcher.
Blueberrytea
But credit where credits due...Poco for its price and specs is a great choice too
dyhyapp
In general, what are the advantages of Mate 20 Pro over the p20 Pro?
