Huawei Mate 20
1982-1994
I see. Any better idea?
Turn off then I will forget to turn on again when I get home and use up all my data.
Use old skool method.
Paste NFC tag on the wall of your home.
Tap it whenever you are out of house. On your NFC for good.
gn2807
i bought mine from mobile hardware (orange sign) at burlington sqaure. no delayed response with fingerprint. i think it was $25
Company wife go there stick, checked all clear of bubbles, reached home, 1/4 tempered glass all bubble. Waste $25
chenaz
chenaz
Me lor. Used it for 2 days and nv look back.
Good thing is the both side of the screen can be back button.
I use the virtual button always accidentally press on the home button when typing .
Do u guys use gesture navigation? I find the back gesture difficult to trigger. Coming from note 9 previously , the stock andriod nagivation were much easier.
mahcosg
if only it has a headphone jack, now must look into getting a bluetooth earphone liaoz
TheCaffeEspresso
My Mate20 lockscreen like hide information of apps eventhough app setting from phone already set to display at lockscreen.
Any solution?
E.g. music app show at lock screen but no song information and music control
Sent from HUAWEI Mate 20 Blue using GAGT
Audiology93
Any solution?
Just tested in mine and there's music control.
Sent from HUAWEI Mate 20 using GAGT
htngwilliam
China has a new membrane type of screen protector. Looks pretty good and I believe OK for curve screen also. I also don't like curve screen but I guess it works it u want small size yet optimise screen size to max
ZergRush
I bought UV glue glass from carousel seller Okonz.
Cheap and good cos he did a good job in applying.
inviztj
Some questions regarding screen protectors for Mate 20 Pro:
1) How strong is Gorilla Glass in protecting the phone from scratches/fall? I've watched some long term reviews on Youtube and their phones do have scratches on them.
2) Should I just get a normal plastic screen protector instead of tempered glass, if the Gorilla Glass is strong?
3) Will a screen protector affect the in display fingerprint scanner?
kryptonit3
just get uv glue type tp glass... curve tpu protector does not last long.
ZergRush
Glass feels better. 95% of the tp sold outside are edge glue. Got 2 kind of full glue which is normal (with side black borders) and UV glue (no borders)
Just go for the UV glue. I went normal screen protector to edge from taobao then non UV (read some negative stuff on UV). At last cannot take the borders anymore. Go for UV to
Best decision ever
inviztj
I was thinking of getting a plastic one just to protect against stretches lol. Though the borderless aspect of UV sounds tempting. A UV glass will be more expensive though, right? $20+?
Anyway, how likely is a screen protector going to affect the fingerprint scanning?
