Huawei Mate 20
klarklar
Can the Huawei Mate 20 support call recording apps? I heard Android Pie disables call recording function. This function is important when having conversation for official use.
Anyone knows? Thank you.
agau168
Anyone dropped the Huawei Mate 20 on the floor? Did it survive the fall? Thinking of buying one but afraid it is not rugged enough to survive falls.
klarklar
Received a mate 20 pro as a gift the day before, and used it without a screen protector. To my horror there was so many scratches after one day of light use :(
I have contacted Huawei and they said they can replace the screen for me FOC.
Going forward, which kind of screen protector should I get? A full curved screen adhesive type? Those "liquid" types?
And will all these curve screen protectors affect casings, for example a UAG one?
Much thanks!!!
Oh dear. Such a fragile phone?
JT2008
https://forum.xda-developers.com/mate-20-pro/how-to/call-recorder-huawei-model-android-pie-t3926346
Work for me...
petricnah
There is an security update coming in.
JayBeeLwashere
Dropped multiple times with uag case no issues
Sent from HUAWEI LYA-L29 using GAGT
gisellevintage
Hi....
Anyone knows if there is a way to remove the white border around the app icons (seems like only Google apps has this white border around it after the update). so ugly looking =.=
karloil
Planning to get a Mate 20. Just to check with current owners - does it already have a pre-applied screen protector (for sealed brand new units)?
molecule
Yes for Mate 20 (not Pro).
Plastic not TGSP. Using it since day 1 now it's still serving me well. ☺
haoKRR
Any case that have their side 'lips' covering higher than the screen protector?
I bought the UAG and Spigen today but the tempered glass is higher than both casing. Confirm hit the screen if it ever drops at the wrong angle..
Sent from Google PIXEL 2 XL using GAGT
leon0079
I'm using uag no issue. Lip higher than tempered glass. Your glass so thick meh?
karloil
Great! Just want to double check as some unboxing videos 'looks' like it doesn't have 1. Thanks for confirming!
haoKRR
Too and bottom lips are fine. But the side, no. You using monarch or plasma
molecule
It is actually quite nice as it provides a slick and smoooth feel (oleophobic?), but initially is a dust magnet, some kind of oil-like coating I believe. Wears off after abt 3-4 months.
Most low end TGSP do not have this and feels pretty rough.
Beefsteak
Anyone knows if the included huawei adapter is the only adapter that can supercharge?
Issue I am facing now is I have a multi usb port travel adapter (non huawei) which can switch between different power plug type. But it can only fast charge but not supercharge.
Anyone knows any multi usb travel adapter that can supercharge too?
