Huawei Mate 20
laeticia
It is actually quite nice as it provides a slick and smoooth feel (oleophobic?), but initially is a dust magnet, some kind of oil-like coating I believe. Wears off after abt 3-4 months.
Most low end TGSP do not have this and feels pretty rough.
I hated the default screen protector film, switched to glass as soon as I could.
karloil
Thanks! Planning to use the default screen protector for the meantime. Been backreading and reading the 'better' TG to use. Keeping my options open for now.
Anyone knows if the included huawei adapter is the only adapter that can supercharge?
Issue I am facing now is I have a multi usb port travel adapter (non huawei) which can switch between different power plug type. But it can only fast charge but not supercharge.
Anyone knows any multi usb travel adapter that can supercharge too?
I believe Supercharge is Huawei proprietary - so you won't see it in any 3rd party power adapters. We are stuck with just PD and QC enabled travel adapters.
karloil
Just got a black Mate 20. I don't think back glass is Gorilla Glass - I've been cleaning it with lint free cloth (new) and it already has micro scratches!!
Aikon
That's because only the Mate 20 Pro has gorilla glass. Not even the P30 Pro has it!
https://www.corning.com/gorillaglass/worldwide/en/full-product-list.html
karloil
A bit OC, the micro scratches only shows when I shine a flashlight - but under normal light, nothing! :s22:
roxas93
Anyone who went for screen replacement for mate 20 pro, usually takes how long?
Aikon
I believe this is just my new gadget OC kicking in. Give it a month or 2 then I wouldn't give a damn :D
Yes if need to shine torch then can see, forget it lah 😁 Also if you have a case on you can't really notice.
petricnah
Replaced screen a few weeks ago due to faulty earpiece. Took about 1.5hr at Jurong service center. Was there weekdays, about 2pm, not many ppl.
karloil
TGSP at XGear Waterwaypoint is also nice! Cheap too at $15. I'm using Spigen Rugger Armor and the TG just fits nicely to the lip of the case.
