Huawei Mate 20
5feet9
Am thinking of changing to Mate 20 which is currently going for $528 at Challenger, but Oppo Reno Z at $399 seems quite good too. Any advice?
Skyy
Can't advice on the Reno but I'm using the mate 20, it's a damn good phone if u're not into bells and whistles like reverse wireless charging or optical fingerprint scanners. The cam is good, speed is fast, screen is big (and flat which is good for screen protectors) and battery life is stellar.
gisellevintage
Anyone can advise...
not sure whether to get the Mate 20 or P30.. as I read online that the P30 has the double tap to wake function which I tink is useful whereas the Mate 20 does not hv it.. other features wise..anyone noes which model is more value to get?
currently using a Mate 10 and have been waiting to upgrade. initially waiting to get the Mate 30 but since announced that it does not comes wif Google so cnt buy alr zzzz...
1982-1994
Double tap jiak battery.
Fingerprint scanner on the rear works promptly. And mate 20 has bigger battery too. Brand new can get at probably $400+
Skyy
Why stop at p30, jump straight to p30 pro la. That is likely to be Huawei's last greatest phone with Google services.
2xEng2xCheng
Is it worth to get mate 20 pro now since it came out 1 year plus ago?
Sent from Xiaomi REDMI NOTE 5 using GAGT
1982-1994
Wah both of you do not mind a year's old phone, saved few hundreds.
$520 is a good buy.
2xEng2xCheng
How much is consider a good buy for pro?
haoKRR
I have a Emerald Green, starhub invoice dated 13th August if anyone is interested.
With a $39 SP from a store at burlington
Sent from HUAWEI LYA-L29 using GAGT
TitanSmall
What's the price you looking at?
Jlyong0008
Mate 20 most value for money. It is still unlocking fast and battery last a long long time. Using both face unlock and fingerprint.
Agree the supercharge is not the fastest around but it is FAST enough. Beside, after my lesson with Samsung, I usually use a slow charge to boost it up. Don't want the battery to spoil too quickly from the heat that comes with super charge.
Only have to get used to the Huawei UI and some apps don't play well with it. The background management is very aggressive. I paired it with my Samsung Gear and the connection breaks sometimes.
