Huawei Mate 20
shichuanhua
Update on qty left:
Mate 20: 2W 1R
20 PRO: no more
20X : no more
Still have Nillkin Frosted Shield left
Mate 20 : 2 White 2 Red 1 Black
Mate 20 X : 3 White 2 Red
Mate 20 PRO : 1 Red 2 White
Give away for free as they occupied space
Self collect @ Admiralty MRT/Woodlands Crescent
Qxpress $4.5
Normal mail $1.15 not responsible for lost mail.
Contact me via whatsapp thx : https://wa.me/6587618185
Torenoo
Hi guys, can i check if this phone able to "double tap to wake"
or wake and uplock the phone when its lying on its back (fingerprint scanner at back)
PholkLorr
One thing i dont like about the video recording of the mate 20 is that it is too zoomed in. If i go to Normal photo mode (not the wide angle lens, which will be even better), it is able to capture a wider FOV than video mode.
Think is cause it doesnt use the 12mp camera
bystander1965
The last I checked, nop.
The closest I get is to use face recognition and let the phone wake on pick-up.
Or you could practice to accurate put your finger on the censor when the phone wakes up. :s13: But the finger sensor performance deteriorates over time I feel, much like what Samsung did a couple of years ago. Very irritating.
So far, the face recognition has served me well, although sometimes I wonder if any tom dick and henry can also unlock it.
Torenoo
which sensor you mean? fingerprint scanner that sensor ?
bystander1965
Ya. If you are good at it, it's a one-touch unlock. :s13: Take a bit of practice to aim accurately. But it doesn't work well after a while because as said after a while the performance of the sensor deteriorates.
haoKRR
Phone will auto lock after plying for a while on fifa. Anyone kena before
Sent from HUAWEI LYA-L29 using GAGT
Skyy
mine still good, almost a year old.. still unlocks in a flash
5408854088
https://consumer.huawei.com/en/support/how-to/newbie-guide.global.en-us00414577/
What is the PD protocol and which phone models does it support?
USB Power Delivery (PD) is a new charging protocol. It can be used to charge devices with different charging capabilities (up to 20 V/5 A). PD allows both data transmission and charging to be bidirectional. It is also compatible with USB Alternate Modes, allowing connections to other types of ports, such as DP and HDMI.
The following phone models support the PD protocol:
P30 and P30 Pro
Mate 20, Mate 20 Pro, Mate 20X, and Mate 20 RS Porsche Design
Mate 10, Mate 10 Pro, Mate 10 Porsche Design, P20, P20 Pro, and Mate RS
Mate 9, Mate 9 Pro, Mate 9 Porsche Design, P10, and P10 Plus
HONOR Note 10, HONOR V20, HONOR 20, HONOR 20 Pro, HONOR Magic 2, and nova 4
GoodBetterBest
Mate = Samsung's Note
P = Samsung's S
So P and Mate can be said to be from different series. Mate series usually get the latest SoC while P series is half a generation later, so I'll only go for the Mate.
Sent from Samsung SM-G975F using GAGT
How the Nova range matches the Samsung ?? Thanks very very much.
andrewkb
I tried to enrol my face for Face U lock on my M20Pro, however it takes forever to register and never ends. Any idea why?
