Huawei Mate 20
friedapple
Hi guys, just updated to android 10 as well. How do we clear cache? I used to do it after every software update but the volume up + home menu doesn't have the clear cache option anymore. Instead I see clear data. Is that it? Thanks
1982-1994
Can share how you downgraded to 9.1? Thanks
Backup your phone first.
Under phone settings,
1.search for HDB and allow it, open hisuite
2.connect phone to PC and click yes to allow connection on your phone.
3.click on upgrade on hisuite
4.click earlier version
Your pc will download the firmware and it will do the installation on the phone. Just leave it alone without unplugging the cable till the phone gets to the startup page
friedapple
Thanks! Noted on the backing up of data, but does the downgrading of firmware really deletes all data?
mingean
Hi
Select clear data, u will see 2 more menu options, one of it is clear cache.
1982-1994
bought a mate 20 non pro brand new at $480, missing its radio FM.
having the big and small one together.
holding the small one feels good
JayBeeLwashere
New OS update to fix call bugs and December security patch received per Singtel. Anyone downloaded and able to review?
Sent from HUAWEI LYA-L29 using GAGT
