Huawei Mate 20
algerr
Guarantee premium on that day at CWP
To add on..seems premiums are given out when purchase at the roadshow..
As for purchase at Challenger, premiums given are excluding speaker..
Lastly for Telco..seems premiums are in limited quantity at certain places..see screenshot from Huawei Facebook below:
Sent from Nokia 8250 using GAGT
kenche
From the reply to other users were while stock last and not guranteed. Maybe they just wanted to assure this user? Still it is better to be early to avoid disappointment.
Yes already mentioned a lot of times only purchase at CWP comes with the premium.
And the 3 other stores in the 2nd image you posted, some mentioning 50 sets per stores.
James Tang
How they guarantee premiums sia hahaah
As I have suggested, if they really ran out of stock, they probably ask you to collect at a later date, as long as you made the purchase in CWP; unless they have prepared 1:1 premium and phone, which is unlikely
athenodorus
Actually I seen some reports online that mentioned that current phones that uses optical in-display fingerprint sensor isn't really considered to be really better than existing physical capacitive fingerprint sensor such as the one on Mate 20 and 20 X.
Accuracy is actually still better on physical capacitive fingerprint sensor.
Umm it’s not meant to be better than the physical fingerprint scanner, at least not so soon yet. It’s the solution to having more screen by removing the front physical fp scanner.
kirium76
They quoted "only at CWP atrium for the redemption." maybe they really have 1:1. The question is whether they have enough m20/p stock at the roadshow. Last nova 3i launch rosdshow ran out of stock for the gradient color. To be collected at a later time while freebie was collected on the spot.
Sent from Samsung SM-N950F using GAGT
s-ghost
High Honorary Member
i think the reason they ask people to fill in the form is to gauge how many sets to prepare also
s-ghost
someone please show me how pro version with casing how it look like, i want see if the curved screen is still super obvious
petricnah
The external of the Pro version made up of Samsung S8/9 curve screen(90% alike) and Apple Xs notch(85% alike).
prayerboy
Can be read another way. It is only guaranteed that you can get that set of freebies at CWP. If you buy elsewhere, or another day, no guarantee that you will get the same set of freebies.
If you read the other replies in the same post, they still say “while stock lasts”.
kirium76
I saw the M20p demo set at huawei bugis last night that has tempered glass (not covering the notch) applied. It covers the full curved viewable display. But dun think it's the default out of the box. Quite thick glass.
junjie433
I read it as guarantee freebies but may need to collect another day if while stock lasts.
