Huawei Mate 9
bermudas
there's a more direct way if you are taking a screenshot to share..
just hold down the home button, tap share, a screenshot will be taken without the overlay menu, select app to share
Eh cannot leh...
Can meh?
I just tried but cannot lol
On gagt app
Sent from HUAWEI MATE 9 using GAGT
Maybe only for Mate 9 la.
3 ways to screenshot :
1) Press volume down together with the power button at the same time.
2) knocked on your screen twice
3) Drag down from top and press the screenshot icon.
Thanks dude!
Make it 4, with the "Press and hold power button then select share" method. That's part of Google Now, I think.
Maybe will need GNow.
you can subscribe to google now, and long press home gives you screenshot.
Thanks Boss!
Jeremy1
I like that it's not heavy, what do you mean block the fingerprint behind?
Like when you are charging and using the phone at the same time? Too big that it blocks the back of the mate 9?
Yes, my colleague just use it first time and he told me the charging speed was pretty amazing.
Yet to confirm again with him.
Swiftyz
I just joined the Mate 9 community! Ill feedback again after I start using the powerbank.
Any recommendation for the tempered glass screen protector and casing/smart cover? :s12:
Jeremy1
If I wanted to get the temper glass, I will get the spigen one. But don't have for mate 9 & I don't know will they make one or not.
For case, I had already place an order. Now waiting. Will post here once received. Spigen is also good but I don't like the look and design.
Jeremy1
nope bro, was wondering anyone had this issue or came across and how to solve it..
I used to have this issue so I played around with the settings and now no more delay liao.
I really cannot recalled what did I change. I am at 138 fyi.
geofoocy
yup have tried this as well. Still delaying msgs coming in
Try this, mine was solved
Apps, google play services, data usage, swipe down and allow background data.
Yet to know it's used for what other services, just have to watch Ur data. Whatsapp need google services to work properly.
Audiology93
My case and tempered glass both from taobao. Tempered glass quite nice. No air bubble after applying the "liquid". For case, can go to the standard shops and get the Spigen Rugged Armor. It's very nice.
Sent from HUAWEI MHA-L29 using GAGT
walkofwinners
Yup I second spigen rugged armor. It's a beast though it adds a bit of bulk.
But with that case, u don't have to worry if ur phone decides to go for a flying road trip.
