Huawei Mate 9
wcmonk
Hi,
Just got the phone two days ago do like to check the following
is there any default function to lock the screen? cause i scared if keep pressing the power button to lock it, soon or later will have issues with the button
and I notice that the in call option doesn't have the call recording function can any one advice how to enable call recording ?
I search the official site it show that the top left should be audio recording but the button on my phone is not
http://consumer.huawei.com/en/support/faqs/detail/index.htm?id=114034
Thanks in advance
TheCaffeEspresso
Hello users.
Before I sleep I do a clean up and close all my apps. But I did leave my wifi on so the phone will still recieve WhatsApp msg. The battery drop 5% overnight after I wake up.Is that normal?
Why is idle so high %tage?
Sent from HUAWEI Mate 9 Gold using GAGT
weixiang80
gotten the phone~~ camera is very good!
Which LED notification app you guys using?
i am using light manager... and does it have to be "running" for it to work properly?
Audiology93
Hi,
Thanks in advance
There's 2 years warranty. No need to worry about the power button being spoilt. Anyway there's something called Floating Dock that's the same as iOS assistive button. You can lock your screen with that.
No please, NOOO.
Sent from HUAWEI MHA-L29 using GAGT
ZhuTou!
On a side note on my mate 9 weird thing grab app not able to pick location, and look at the vehicle options it's giving me. Hahahah
Gps issue
The toggle button on the top is not gps, its location instead, diff from the usual android phone
Go to the setting and choose high accuracy, gps will be turn on when u toggle the location button
If u off the toggle to off gps, even normal location will be off
Sent from HUAWEI MATE 9 using GAGT
