Huawei Mate 9
Norman Chan
No.... you can even use it to transfer IOS iphone to Andriod Huawei
It done what it supposed to do but for Lines, WhatApps, Viber , Kakao Talk and Wechat, all the messages cannot be clone over and the sd card both photos an videos also not clone over. Normal SMS fully clone over without problem.
r0_ger
For WhatsApp, you have to copy the folders over before u install the app on the new phone. Read up their FAQ.
kaysee
still thinking if i should get this phone via re-contract on M1 or buy the phone itself from Hitech mobile and switch to circle life. :s22::s22:
combatuser
Unfortunately there is this funky huawei software which will allow to go back to b110 , but the dev of that software doesn't have the b110 firmware, he only has 136 and above
Search XDA for the offline B110 update and download it. It is a zip file. Drag the dload file inside the zip file into external SDCard. (Phone\External SDCard\dload).
Then power off phone.
Hold volume down, volume up and power button together (3 button combo) then after awhile, it will flash B110 update.
NOTE: It will erase data. It is recommended to factory reset from the phone itself after flashing the B110 update.
ThErMuS
Just updated to b138... the battery is a lot more worse than the previous one ..... cannot than as I'm a someone who is always on the phone... morning 7am till 7pm left 10%
KeYoKe
anyone can share if u are using the stock screen protector or TG?
if TG can share which one u all use and where to purchase?
warr
using Mate 8. and now Huawei has released Android 7 and EMUI 5 to Mate 8.
No regrets on their software support and a cleaner interface of EMUI 5.
beats Samsung on that.
KeYoKe
makes me more confident to be able to get software updates for my second year. last time huawei dont do software updates for their older device :s13:
MichaelTan
Please reinstall facebook and facebook messenger.
