ZhuTou!
- Oct 6, 2008
Use mini lordefine more "human" hahaha...
so wad app u are using for fb and messenger now
Actually no diff from web la
Sent from HUAWEI MATE 9 using GAGT
Probably ur setting issue baAlready done that but still the same. That's y they ask me to do factory reset.
Last me a day before upgrade. Now less than 3/4 day.
Noted. I'm on GAGT most unable to can't see any PM. Will read it when I get home.thanks bro... anyways i got pm u with regards to the lockscreen, realise ur lock screen looks a bit different![]()
No issue. What issue have you heard of???hi users,
Just wondering, does the UFS 2.1 flash memory giving you any stability issue ?
Can any of you enlighten this ?
Dun worry its safe. I got mine from RedWhite.Hi all,
Intending to get a new Mate 9 without contract. Have been sourcing from telcos (RRP at $898) and shops from Bugis and Far East Plaza (eg. WhyMobile) ($755).
The price difference makes it so attractive to buy from shops like whymobile or their competitors.
- Anyone has good/bad experiences with these shops?
- I know they are good at selling used phones, but for new phones can I buy from them or I should go to telcos?
- I read that these shops normally selling signed sets, and yet they claim they can provide 2 years local warranty, is the warranty really valid? In this case, how does the warranty work?
Seeking for advise.
Thank you in advance.
Guess not. Went to Challenger at JE and JP but they don't have it.anyone know if west side of Sg where got sell the original charger ?
Like that mine Jialat. I traded in my iPhone 7 plus so the receipt is very weird with both iPhone 7 plus and Mate 9 inside.mine is a agent set as its BNIB (totally sealed) and they open the seal in front of me.
I have official receipt from Hitec Mobile, they put the SRP ($898) in the receipt as they say that Huawei will question if the price put in the receipt is too low.
Mobile hardware also tell my friend about this when he wants to send his set to service (they ask him to go down and get a official receipt with the SRP, instead of the price he bought it at ($760)
Anyone has problems with GPS and compass? Mine doesn't seem accurate
Sent from HUAWEI MHA-L29 using GAGT
anyone experiencing Bluetooth audio player problem ? I tried to connect mate9 to my car as an audio player and it can't connect. phone call is ok though. driving an Audi. used other phones and they are all connected. sian.
Same usage pattern here, but it's not an issue with the phone. ALL Android will die within a day for me cos im syncing like 8 accounts. Of all the androids, mate 9 has best battery life
It drop 25% overnight (12am to 7am) without using with WiFi off. Is it normal? Thanks!
no one else facing this problem?
defintely not normal. check for wakelock, see which app is causing this
I off all apps except WhatsApp when screen off. Android system is the one used up 50% of the battery power as shown in power info most of the time.
try clear system cache and see if it helps.
Guide:
https://recomhub.com/blog/how-to-clear-cache-on-huawei-mate-9/
Not normalIt drop 25% overnight (12am to 7am) without using with WiFi off. Is it normal? Thanks!
