Huawei Mate 9
r0_ger
No leh, i am using Singtel SimCard.
it is showing MHA-L29C636B172
What't the change log?
My phone resetted itself yesterday, went into Safe mode. Dunno what happened. After I restarted it, my apps folders all gone and all my apps are like all over the place! Had to redo the arrangement...
Gondon72
Optimise system stability and battery prrformance
chris1987
http://www.hardwarezone.com.sg/tech...omi-mi-power-bank-pro-we-tell-you-differences
Dear Bros, I recently ordered the xiaomi powerbank pro 10k MAH from Lazada (29 bucks with promo) and got the newer version by sheer luck or coincidence.
Good news is that fast charging works!
Unfortunately my spare wire only allows fast charge.
I will bring it back tonight to test with my cable that allows super fast charging to see if it supports the speed.
KeYoKe
cool man, if it works can post the link and we hoot :s13:
Oinkize
:s12::s12: hope battery life is good... can keep us updated on the batt life for b172? i am camping for it liao.
i have switch to msia sim card but cant get the update
May i know why you have to use a Malaysian Sim to try?
xtemujin
No update to B172 tried using the Malaysian sim and I'm on Singtel too.
bermudas
I'm having an intermittent charging issue with my Mate 9. Every few days it will not respond when charger is plugged in, and then I'll need to restart before it recognizes the charger and starts charging. Anyone else encountering this issue?
Hi,
I have this issue. I will need to restart the phone.
I am also having a similar issue with switching on the mobile data. At times, i will need to click on "mobile data"... then it turns blue for couple of seconds.. then gets disconnected. I will have to enable it AGAIN in order to use my mobile data.
Anyone else having this issue?
I am on Mate 9 Pro tho.
jiayelim
Hi,
Morning,i am on m9pro too,no problem so far,been using two months..
