Huawei Mate 9
benny888
hi i have a strange problem. the knuckle options doesnt work even though it's enabled under smart assistance. i had mate 8 and it worked perfectly there. the phone registered my knuckle as normal touch. i can't knuckle x 2 to take screenshots and also on. any bro can advise what could be wrong? thanks much.
Hardware issue ? Mine works easily well
tcchuin
me long time no buy handphone duno the pattern of when pricing drops..
very nervous dealing with qoo10 handphone shop
one seller sell with the 64gb msd but box got open
one sell without msd, when ppl ask got give or not, say must sms to ask... i dun understand why like that so gui gui sui sui one..
i also ready for recontract... which ish ard $630+
just that not sure wanna sign or not cos thinking of jumping to m1 mysim plan
if they're authorised reseller huawei will honor the warranty according to the receipt given. I think it's better to go for m1 mysim plan since at least 400 dollar savings over 2 years.
bulsara
I'm having an intermittent charging issue with my Mate 9. Every few days it will not respond when charger is plugged in, and then I'll need to restart before it recognizes the charger and starts charging. Anyone else encountering this issue?
newcell
Using a transparent rubber case, power button not flushed. Can feel and see the contour around the button.
StealthNinja
it might be faulty cable, did u try using another cable?. :s8:
1c3_5n0w
for me, only a few of the knuckle gestures work. namely the one where you can circle the area you want to screenshot. the double knock one isn't working for me too. I think could be due to our screen protectors. it isn't a hardware issue as well because your touch screen works ma. no cause for worry unless you really need the feature. quite gimmicky imo.
Oinkize
I noticed that on this b158 wifi is always on even though it was set to connect only when plugged in...
