Huawei Mate 9
chris1987
Dear Bros,
Regarding the Xiao Mi Powerbank Pro, unfortunately it only fast charges the phone which is already significantly faster than normal charging using powerbanks that support QC instead of HiSilicon charging.
For those that are lost, Xiaomi has this particular powerbank model that can be found here:- http://www.mi.com/sg/pb10000pro
I bought mine last year and it was still PLMZ01ZM.
It supports QC but not compatible with HiSlicon Technology which is Huawei's Fast Charge tech.
Do note that some shops are still selling the older version which is what you do not want to get.
Look out for PLM03ZM if you want to get it for your Huawei =)
PS - I tried my luck and got the latest version from Lazada (Shop name is ISKY Trading)
After promo code its about $30.
ZhuTou!
Hi do you now quit app using the arrow button all the way back till app gone or just use home button to exit?
Sent from NEXUS 6P using GAGT
for fast quit, tap the bottom square button and click X on the app
normal quit just left arrow all the way
some app have to left arrow alot of times to quit, so for this kind of app use the square button easier
press home button is to minimize the app, not quitting so it will consume ur ram
but mate 9 alot of ram la so no issue lol
LonelyMan
Dear Bros,
So after so much stuff you shared, the Xiaomi only do normal charging for the Mate 9 right?
KeYoKe
update fimware liao bo?????
LonelyMan
Long story short, only the latest version of the xiaomi pro powerbank is able to fast charge this phone.
Can u test the charging speed of the power bank using qc3.0? How much time is needed to charge the power bank from 0-100%?
friedapple
if we clear system cache (and not factory reset), will our apps still be there or do we need to install it again?
thanks!
