Huawei Mate 9
KeYoKe
for people searching for a tempered glass screen protector that's well cut I suggest the x-one screen protector. 70RM at JB inner city and compatible with Spigen armor as there is slight leeway at the sides unlike those full coverage protector with the oil solution and brush. 23$ settle once and for all bloody worth it. feel free to PM for pics :)
X-One is not TG anyways, it is a mixture of silicon and dont know what material. hardness is only 5H while TG is 9H. so it is more prone to scratches
iguoh
I get this message popping up on my home screen now and then:
"WhatsApp is currently recording audio. com.google.android.googlequicksearchbox:interactor will not be able to record right now."
I did a Google search and one of the recommendations was to turn off quick control in the voice control settings. I tried it and the message still appears. Anyone found a solution to this? It only started happening recently so I am not sure what is causing it.
1c3_5n0w
yep I'm aware, they don't market their products as tempered glass for a reason. but the cutting is really excellent. my full coverage one accumulates dust like crazy for some reason.
xolatw
Same here. Would like to know how to fix too
meekiatah
Need to delete your ok Google voice training then the seeing will be disabled.
It's showing that message because you have Google assistance and it's set to listen for your voice anytime, anywhere. When you use recording app like voice recording or video recording, then the message appear.
aardvarkgeo
Was so annoyed with this I disabled the Google App... Never really used voice to search or anything on the phone.. so was good fix for me
Sent from HUAWEI MHA-L29 using GAGT
iguoh
It seems counterintuitive though that Google Assistant has to be disabled. Isn't this what it is designed for? If this is the only solution it has to be a firmware bug.
KeYoKe
Mind pm me the pics? I wan see see how is it. This week i going in JB haha
newcell
Thanks for sharing.
Removed and monitoring, hope can improve battery life. Quite a large file.
kiawui
Hi kiawui,
Kindly send us the IMEI of your device for our follow-up with Huawei.
Thanks.
Hi TheCaffeEspresso,
We've dropped you a private message yesterday to request for your device's IMEI.
Kindly check your inbox and reply. :)
Hi. Not sure if this Singtel is genuine. Please email me at kiawui@gmail.com so I can reply with my imei for you to check. Thank you for your assistance.
