Huawei Mate 9
StealthNinja
Hello all! been reading quite abit of this thread to know more about the Mate M9..
iPhone6 going to ki cha soon and i dowan ip7 or 8 cos no 3.5mm jack and dont wish to jump on the samsung ship..
Currently thinking between this and the Asus Zenfone3 Deluxe...
But this is quite enticing for me due to the battery life... just need to get used to no buttons on the bottom...
I wanna ask if i use other adaptor and cable, isit able to charge the phone?
If yes, how long approx? does it charge at 2A?
And what are the cons of this phone? (Pros all the reviews have said alot.. just wanna know the cons from you users firsthand)
Thankssss
-the battery cannot remove
-camera ui is a bit complicated too many function
stillgottheblues
We use to be able to disable Google Keyboard. Now we cannot disable after it had been updated to GBoard.
Is there any way to disable it by some hack without root?
xtemujin
You have to install the Hisuite app in the handphone and for the computer.
manofsorrows
Hi all, does the mate 9 comes with Google Assistant installed ? If not how to get the Google Assistant in ? Went to Huawei service center but no one seems to know what is Google Assistant. Got confused with Google Now. Thanks.
Oinkize
As long as you have the latest Google search app updated and you do the same step as how you will activate Google now, Google Assistant will be activated.
thorsten139
Bro what u meant by go to locations
Sent from HUAWEI VKY-L29 using GAGT
Basically even if you turn off wifi, the wifi is actually still on if this option is enabled.
The way to access it on the mate 9 is to pull down notifications tab, press and hold on location icon, which will bring you to the locations menu.
then follow the instructions in the prev post.
aardvarkgeo
Set language to American English as well... That is how I got it..
Sent from HUAWEI MHA-L29 using GAGT
tekster
Any bros hoot mate9 pro from china? Worth hooting from china or malaysia?
