Huawei Mate 9
mbgeow
Hi guys, sorry for noble questions, may I know how to backup everything on my phone before doing factory reset n send in to Huawei service center to change the battery? like in use what application to backup? thanks in advance
JPadPro
1. You can use the HiSuite to do phone backup before sending in
2. You may also use other Android backup apps (up to your preference) to do phone backup.
chromatin
mate 9 camera can't focus
my mate 9 camera cant focus in color mode. always get blurry picture at one corner. check forum said camera lens has shifted when drop on floor.
ask service center was quoted $108.85 to replace a new camera lens bcos my set out of warranty (28 Dec 2018).
should i go for it or upgrade to mate 20X ?
highsulphur
Upgrade.....
bermudas
I had this exact same issue as well previously and decided to purchase the M10P in January 2018.
I wouldnt bother replacing the camera lens at that price.
wcmonk
hi, like to check any1 here on tunein radio app in your mate9?
recently i’m keep seeing a notification “third part application connected to tunein radio” and it just show at the top and display by itself, which i didn’t have time to screen capture it.
does any1 have have the same notification ?
alex22
Dun use this app...
meekiatah
Wat the reason fo4 changing? And need wat to change?
Just complain battery drain issue. Need to do full back up of your data as they will factory reset your phone.
Bonus: changing the battery will also change a new screen for you as it's connected. That will also mean you need a new screen protector.
nannan82
den took how long?
meekiatah
den took how long?
They will tell you up to 3 working days. I did mine at 313 and although they told me up to 3 working days, from experience, they are able to do it quite fast. I had my screen cracked and replaced by them before. FOC, of course. So, I told them that I'll be in the area, and if by chance, they're able to finish it soon, can give me a call to pick it up. Sent in about 5pm+ and got the call from them about 6:30pm to collect it. This is during last Dec when they are busy with Mate 20 Launch + Gift Redemption at their 313 store.
