Huawei Mate 9
moonSymph
User experience wise both should be the same.. Mate 9 hardware is faster though..(processor,graphics and storage).. Screen wise mate 9 wide gamut IPS is more pleasing than p9+ amoled imo..
If you use two sim card then mate 9 win hands down..
user experience is mate 9 better than P9+?
123xyz
Just got my huawei mate 9,
I realize there is a thin display film on the front screen
Do u guys remove the original display film before applying tempered glass or paste the tempered glass on the film?
I realize the film is stuck to the screen seems hard to be removed.
I wonder if the touch sensitivity will be affected if i paste the tempered glass on top of it
aang1971
it a screen protector
trd2970
Remove it before putting tempered glass
predatorgx
Anyone has issue with the touchscreen? Currently unable to scroll down a list via at the two edge of the screen. It would just be unresponsive until I choose to scroll on an area away from the screen.
Currently running on B110
maxokw
I am having random scrolling issue. switch off the screen n on it. it will goes off... duno wats the issue...
ZhuTou!
I have join the dark side :crazy:
Sent from Turbo Inside!!! using GAGT
Jeremy1
Anybody know how to disable the lock screen on Mate 9 so no need to swipe everytime when press power button on standby mode ?
Thanks.
