Huawei Mate 9
123xyz
My huawei mate 9 purchase from Lazada comes with 2 IMEI number.
Is there a possibility that is a fake ?
Do all mate 9 comes with2 IMEI number?
xtemujin
I did try the Firmware Finder app and like those posted on the XDA forum, it does not work.
Only able to upgrade to the B136 firmware using a Malaysian prepaid card but using wifi to download it.
HTH.
Yeah even if I download the full rom from elsewhere and place in dload folder, there's no local update option in our updater app.
Tried the force update also say update fail. Sianz..
Audiology93
Actually my concern is can I use normal power adapter which gave 2.4A output to charge Mate 9 as it's supposed to use much higher Ampere of 4.5A.
Lower Ampere should take longer time to fully charge it but lower current will it damage it in long term charging.
Unfortunately only by using the original cable and adapter will you get 4.5A. Doesn't work with 3rd party accessories. That's what the staff at 313 told me.
Sent from HUAWEI MHA-L29 using GAGT
Jeremy1
http://m.ebay.com/itm/262735148080?_mwBanner=1
