Huawei P30 Pro Accessories Thread
chanbri
Anybody using huawei cases? Wallet case. And the smart view case. Or even their PU cases and silicone case?
Sent from HUAWEI VOG-L29 using GAGT
xiaosen
Is okonz uv loca tempered glass hard to paste? Any shop can help to buy and paste?
garettlim
Just posting what I've done to help others avoid the same mistake.
Case:
https://shopee.sg/user/purchase/order/1211413302/?shopid=126422333
Got my p30 pro case from here. I like how there is a sufficient amount of raised edge for the camera since it's why most of us bought the phone. But the volume and power buttons are quite rigid and hard to press. Not that we need to use the keys often anyway.
Anyhow I decided to purchase a Ringke Fusion Space Blue cover which is shipping over. For reasons which I will explain next.
Screen Protector:
https://shopee.sg/product/86788326/2051403974
I wanted to grab something fast and cheap so I could use the phone soon. So I got this. The buyer took awhile to send it out. Received the pack of 2 TGSP which had only glue on the edges. My first TGSP wasn't aligned well so I took it off and redid it. Sensitivity was off at the edges and the SP was popping off the screen. I thought it was because I had damaged the glue.
So I removed the entire SP and loaded a new one. This time I aligned it correctly on the first try. But noticed the SP was lifting at the bottom edge again. Not sure if it's poor quality glue or just the case pushing it off.
I also noticed on both SP used that the proximity sensor was notifying me that something was obstructing it. Could be the glue or the SP itself. My advice is to avoid the proximity sensor when putting on the SP.
Anyhow, I'm heading to purchase a full glue UV adhesive SP from Okonz. No idea if it's worth the bucks.
Does anyone know if using UV Loca SP would void any warranty from Huawei? I'm a first time Huawei user.
Update:
Got my okonz loca TGSP installed/pasted at Tamp. So far so good. First time paying 20ish for a tempered glass. The anti-fingerprint feature is awesome. Even after a workout and tapping with sweaty fingers, I don't really leave much behind on the screen. Noted that the top and bottom of the glass is a tad bouncy/springy but it has definitely not lifted significantly off the screen yet.
Will update again when my Ringke Fusion case comes in next week. Hopefully it doesn't lift or hurt the new SP.
rainbowsoverljy
Case:
Screen Protector:
Update:
I bought from okonz also. So far so good
asdyui31
any idea if there is any retail outlets or shops that carry okonz sp? i sucks at pasting, cant buy online.. :s22:
JAson1980
I have Cafele and Nillkin tempered glass screen protectors as well as a bunch of cheap TPU cases coming in from Aliexpress, will update when they come in. the Nillkin one for my P20 Pro worked really well, fingerprints didn't stay at all, but the main issue for the P30 Pro is if these protectors will adhere to the curved screen.
I got both Cafele and Nillkin tempered glass screen protectors , one on my phone and one on my wife's phone. Both got the rainbow effect. Is it the same for yours?
Johnteoh
Update:
Hi
May I know which shop is that? I can see dust gathering on the top part of the screen on mine so I want to change it.
superio
Help! I bought the UAG Frosted casing for my P30 Pro but after putting it on, my tempered glass came out.
Anyone knows which tempered glass/SP would be suitable with the UAG case?
maumu
Is otterbox symmetry clear or spigen ultra hybrid better?
Computeron
I just bought a case today. Brand name is vanguard.
One of the shops boss said spigen now is gd for those without tampered glass due to the corners.
Sent from JIAOWEI *呼吸水晶* using GAGT
Computeron
Y this thread so dead?
cokiee
Do you mean is good, or is not good? I understand one concern with covers is that it pops up the curved screen protector if you're using one.
