Huawei P30 Pro Accessories Thread
smileysilka
Hi
How's Okonz UV adhesive tempered glass? Does it cover whole screen including sides or only the top? Fit well with the case that comes with the phone?
Any issues with it so far? Could I seek your feedback on it?
Thanks!
Computeron
Hi
Thanks!
cover the sides. and it fits the given case.
wat i dislike is dust will stick to the top n bottom.
Computeron
Using the Ringke case. Not bad lah.
I found it a bit sharp for those back contours. I just changed to supcase
But puton liao got water mark. Weird.. The cas got dot matrix still have mark. Donno izzit my back gloss sp.
Sent from JIAOWEI *呼吸水晶* using GAGT
tjrong07
Anyone have suggestion for tempered glass that fits spigen case? Most I seen have edges that resulted in the case to push the glass to pop out from the screen.
decibel.
Just posting what I've done to help others avoid the same mistake.
Case:
https://shopee.sg/user/purchase/order/1211413302/?shopid=126422333
Got my p30 pro case from here. I like how there is a sufficient amount of raised edge for the camera since it's why most of us bought the phone. But the volume and power buttons are quite rigid and hard to press. Not that we need to use the keys often anyway.
Anyhow I decided to purchase a Ringke Fusion Space Blue cover which is shipping over. For reasons which I will explain next.
Screen Protector:
https://shopee.sg/product/86788326/2051403974
I wanted to grab something fast and cheap so I could use the phone soon. So I got this. The buyer took awhile to send it out. Received the pack of 2 TGSP which had only glue on the edges. My first TGSP wasn't aligned well so I took it off and redid it. Sensitivity was off at the edges and the SP was popping off the screen. I thought it was because I had damaged the glue.
So I removed the entire SP and loaded a new one. This time I aligned it correctly on the first try. But noticed the SP was lifting at the bottom edge again. Not sure if it's poor quality glue or just the case pushing it off.
I also noticed on both SP used that the proximity sensor was notifying me that something was obstructing it. Could be the glue or the SP itself. My advice is to avoid the proximity sensor when putting on the SP.
Anyhow, I'm heading to purchase a full glue UV adhesive SP from Okonz. No idea if it's worth the bucks.
Does anyone know if using UV Loca SP would void any warranty from Huawei? I'm a first time Huawei user.
Update:
Got my okonz loca TGSP installed/pasted at Tamp. So far so good. First time paying 20ish for a tempered glass. The anti-fingerprint feature is awesome. Even after a workout and tapping with sweaty fingers, I don't really leave much behind on the screen. Noted that the top and bottom of the glass is a tad bouncy/springy but it has definitely not lifted significantly off the screen yet.
Will update again when my Ringke Fusion case comes in next week. Hopefully it doesn't lift or hurt the new SP.
Hi can share what model name of the okonz protector u got? I go their qoo10 shop got many options idk which one?
Sent from HUAWEI VOG-L29 using GAGT
decibel.
u can search on carosell...
Yup I saw that too that's why I not sure what Garrett meant by Loca SP? Is it tempered glass or the UV or the hydrogel version one? I'm looking for those no fingerprints type
Computeron
i'm using the UV.... not much prints. got also easy wipe.
JAson1980
Hydro gel is crap, i was using on another phone. it does not self heal as claimed.
I am using the UV glue on my P30 Pro, I think i did not do a good job. but it still works well, some bubbles and fits the ringke fusion well. It break then i re apply, have 5 pc on standby. No name brand from Aliexpress.
