Huawei P30
Which P30 series color would you get?
  • Breathing Crystal
    Votes: 219 54.2%
  • Aurora
    Votes: 120 29.7%
  • Black
    Votes: 65 16.1%
  • Total voters
    404
ash like snow
you using any case? Mine also have bubbles or rather the edges lifting up. But don't really affect usage much mah.
Who is this ah beng shop? Is it the case pushing the screen protector? The last time I put at RWM, the lady fix it for me and it was fine. It was with a spigen case.
Now that I'm using a uag case which is very tight, there is a bit of bubble at the edge but I didn't really bother.
Alternatively you can try Breakfixnow.com.sg or Casefactorie but these are not cheap.
I'm using the free transparent casing that comes with the Huawei phone. The case doesn't even touch the screen protector at all, so it shouldn't be the cause of it
Sent from Home using GAGT
XiaoFu99
P30 (128gb / 6gb ram) local set with 2 years warranty at $645 (Shopee) ok boh ?
JAson1980
The phone does flex when put in pockets. I guess the difference in tension caused the lifting of the SP. My case do no touch the S also, but the corners are lifting up.
I just got my P30 Pro last week, tried using Google Pay for my transport. I can tap in with ease (very fast compared to samsung) but i don't seem to be able to tap out.
It keeps telling me there's an error or i've not tapped in, does anyone else face the same issue?
barnabaskoh
anyone has any battery charging or battery shorter life after upgrading to emui 10 or rather any issues at all?
I don't dare to upgrade to emui 10 as I am enjoying my phone and worried after upgrading will start to have issues..
JAson1980
Anyone faces freezing of apps for a few seconds? I experienced it a few times liao.
vaxvms
some say yes some sau no
do it at own risk
problem than fatcory reset loh
When it comes to sharpness and against the rest of the market, Huawei P30 does very well but is a bit handicapped by the 10 Megapixel resolution (in auto-mode) against 12 or 16 Megapixel competitors.
rtchlkj
p30 pro email appl
anyone facing issue syncing email on huawei email app. exchange outlook office365?
Yuripa
No problem for me tapping in or out, definitely faster than SS note 10 series (did a comparison with my friend).
Tap from front or back top center also no issue.
Sent from A New Hope using GAGT
Yuripa
Only WhatsApp give me issue.
Want to upload files like videos or pictures will either lag or hang from time to time.
Jhyun
Same encountered this recently.
Sent from Sent From My Mjolnir using GAGT
napster79
Encountered the same after upgrading to Anroid 10. Thinking of facory reset but lazy to reinstall everything. :sad:
haoKRR
Considering to get P30 pro. Will GMS be replaced by Huawei own software ?
Sent from Google PIXEL 2 XL using GAGT
maumu
u guys planning to upgrade to p40 pro/premium or not?
strangely, the other day I was browsing around at challenger, and saw a mate 30 pro which has Google Maps loaded. I tot mate 30 onwards don't support Google apps anymore?
really in a dilemma...
