Huawei P30
Which P30 series color would you get?
  • Breathing Crystal
    Votes: 219 54.2%
  • Aurora
    Votes: 120 29.7%
  • Black
    Votes: 65 16.1%
  • Total voters
    404
Aikon
Ohya which screen protector best suits p30p? I used ahbeng apply a uv glue protector and within 3 days there's like "bubbles" underneath already..
Sent from Home using GAGT
RWM's screen protector was pretty ok. No issues so far.
maumu
I haven't receive any update for EMUI or Android 10... :(
on Singtel (GOMO)
1982-1994
Phones should stick with their default firmwares instead of just update and update. New firmware is for new phones.
Like emui 10, it's for mate 30 series.
lkinm81
Initially it was abit laggy but after a while guess its back to normal
Most likely the indexing is in process after software update. So far my p30 pro is working smoothly after emui 10 update and I just the Dec 2019 security updates too
Yuripa
Does anyone know how to do phone conversation voice recording?
Currently on this build -
Sent from A New Hope using GAGT
Aikon
You have to download and install the file at your own risk yah because it's from xda forums and doesn't belong to me.
http://www.mediafire.com/file/wdauxtttk4tlet8/Gravador_de_chamadas_P30_PRO.apk/file
Then enable it in the settings of the phone caller app.
Note that it can't be done once you are in EMUI10 as Huawei has blocked it from running. I've heard that once installed on emui9 it upgrades automatically into EMUI10. But I haven't tried it in emui 10.
Huawei is stupid to block it though, with the loss of GMS its shooting down all the other compensating strengths.
All the recordings are stored and can be accessed via the Recorder app, under the calls folder.
vaxvms
mini update is fine
but from emui9 to 10 i have yet to update as nothing benefit me from the latest emui from what i know so far
but thats me.....all depend on individual
like i like to use phone naked w/o protection
Yuripa
Thanks!!
vaxvms
anybody know the display brightness AUTO after reboot can be disabled?
tayez80
Hi, What is the fastest way to transfer all data and apps from Samsung S9 to Huawei P30?
limyiqin1998
Does GMS still works for you guys when you update to EMUI 10? The update is 4GB and I'm not sure what they are changing lol
Milo-Dino
Its because its an upgrade from android 9 to 10.
The base Google update is already huge
Posted from PCWX using Some morse code device
