Huawei P30
Which P30 series color would you get?
  • Breathing Crystal
    Votes: 219 54.2%
  • Aurora
    Votes: 120 29.7%
  • Black
    Votes: 65 16.1%
  • Total voters
    404
WTS008
P30... the real flagship killer now... still good for u guys?
1982-1994
But no Google...I still weighting if I need...I been using Google calendar and Google drive for work
oh ya sorry I forgot about google
for work, maybe can consider note 10+,but that's another thread
if you value battery life, p30 Pro definitely is the one
note 10+ has horrible battery life as most users said
soilwork
Thanks for this! Appreciate this
caesium5
Newb question, any advise on where to get a P30 Pro (original, brand new un-open set, local warranty) at a good price?
I am not used to buy things online so is a little confused with started googling for the price. Don't know if the online stores are legit.
haoKRR
Red white, kasia, hitec, moby, j2, mobilesquare
Sent from HUAWEI VOG-L29 using GAGT
mojoe
Samsung Note 10+ horrible battery? Again?? Some things don't change... I gave up on Samsung already, especially they dropped the audio jack now. I think they have built-in obsolescence. My Note 5, 8 and 9... all can't last more than 1yr+ without battery dying fast.
P30 Pro is just great and looks like I will keep this for long since i need GMS.
xolatw
Anyone here uses the phone without case? Just bought it and have no case for now. Afraid will scratch camera lens when placing on the table. Any suggestions on how I can protect my phone till my case arrives?
1982-1994
I'm holding mate 30 pro nakedly,so far ok
just make sure the surface is smooth
haoKRR
Use the case that comes with it for the time being?
Thats what I did
stamina
Hi all,if i buy huawei p30 lite local warranty set now, can the android/google play apps be used and be updated as per normal ?
