Huawei P30
Which P30 series color would you get?
  • Breathing Crystal
    Votes: 219 54.2%
  • Aurora
    Votes: 120 29.7%
  • Black
    Votes: 65 16.1%
  • Total voters
    404
Sambuca78
Did anyone of you buy any extra adapter (40W) from external vendors like the one below which cost less than $30. If so, does it work as advertised
https://sg.carousell.com/p/1007613380
There is also one selling at 18 (LAZADA)
https://www.lazada.sg/products/original-huawei-5v-45a-supercharge-adaptive-phone-charger-with-5a-type-c-cable-p10-p20-pro-p30-pro-mate9-mate10-mate20-pro-mate20x-i282765111-s449490960.html?spm=a2o42.searchlist.list.12.39902927RaEh5y&search=1
Sent from HUAWEI VOG-L29 using GAGT
I bot this Baseus BS-CH910 60W PD Fast Charging Adapter (2 USB + 1 Type C) QC 4.0 Wall Charger Phone PD Charger, primarily use to charge my notebook via the USB C PD port but it also support Huawei Super Charging.
However when I tried this with my P30 Pro, it only charge at Quick Charge speed, and everytime 1 plug in another device, the existing device will reconnect, perhaps that how PPS work?
I wonder if anyone here happen to use the same Baseus charger? Thanks.
santa74
Emui 10.1 available for download now for p30pro 10.1.0.126
Hope it's stable
I updated yesterday evening and I didn’t use “always on display” but it seems that the battery drain faster than the previous 10.0.0.209.
finalforce
I using another Baseus charger, with the digital display of voltage /current.
I get 22.5W supercharging using the USB A end only. Need to make sure your cable supports 5A.
However, once I use the other port also, will downgrade to quick charging I think.. Can't really remember.
Yuripa
Do not install the latest emui 10.1
My 43mp mode is missing.
Sent from Peach Valley using GAGT
Kevctx
I dont know if anyone experiencing the same issues as me. After the Emui 10 update certain apps like Shopee start to lag and I can't go back to the previous page. The only alternative is to force close the app and restart it. The loading is also slow sometimes.
The other issue is when I click on some links the page won't load. It keeps showing that there's some error and I have to keep trying again before it actually loads the page. Anyone facing the same issues?
Yuripa
No such issues faced for me.
Accept for the following :(
kogregory
All the recent updates are like that. After the next batt charge, the batt will be back to normal. That's what I faced so far.
WinHan
I'm having the same issues. Especially Shopee.!
WinHan
It's freaking annoying isn't it? I'm wondering is it really due to Emui 10...
I think it is. Since updating to 10.1. I'm still holding on to my P20 pro on emui 10.0 too but with lesser issues
yhw22
P30 Pro with 10.1, now suddenly I'm unable to show multiple windows by swapping thru the edge.
I had checked it is enabled under setting - Accessibility features - Multi-Window - Multi-Window dock enabled.
Any advise?
yhw22
Manage to use Multi-window. After changing System navigation from Three-key navigation to Gestures.
But previously I'm able to use multi-window in Three-key navigation.
Any ideas what is the issue?
haoKRR
Phone updated to 10 over the night. So far so gd
bundy
Anyone with issue with Google photos.. I not able to have a preview under device.
Sent from Ok, not so nice guy using GAGT
