Huawei P30
Which P30 series color would you get?
  • Breathing Crystal
    Votes: 219 54.2%
  • Aurora
    Votes: 120 29.7%
  • Black
    Votes: 65 16.1%
  • Total voters
    404
Rayall
I'm on 11.0.0.3 but it's a Digi version (I previously had a 2nd msia sim as I travelled for work). Any idea how to get back the Singtel version? I have since removed my msia sim but the updates are still following Digi versions...
keegs
Anyone facing issue on GMS recently and it prompt u to use HMS on some apps? I having problem to sign in using Google account occasionally. Will have to restart the phone to get it work again. I goggled and some website say need to update Android Webview service and Chrome, which I did. But it doesnt seems solving my problem.
Btw, March patches is out.
vaxvms
no problem on emui 9.0 on my blue p30 pro :D
1982-1994
To some users, your phone might be a treasure since it is hard to find a 2 years old phone with the default firmware
Try searching for the first ipad mini with iOS 6,its not cheap
Maybe because it's an Apple product
vibranze
I like the form factor of P30, is it still worth to get the second hand set? How is the camera compared to P30 Pro? Thanks.
vibranze
EMUI11 is based on Android 10? Is there any news from Huawei that P30 is getting an Android 11 update? Thank you.
JAson1980
Guys, where to get the P30pro screen fixed besides Huawei itself? Looking for a cheaper option
yhw22
But if after change the battery, the IP68 will deteriote rite? And more concern is that I need to do a factory reset for repairing.
Yuripa
Saw offer to change the p30 battery from HUAWEI at $50. Is the price worth it.. My p30 pro is about 2 yrs old.
From the Doc
Access huawei app in your phone, check the price and make an appointment with the help support personnel from the app itself. The battery price is +/- $20 excluding service charge (I forgot the amount already). But as and when huawei will have servicing promotions etc, so best to check the app in the phone itself.
He or she will assist you accordingly and inform you of the final price.
Take note since its a water proof phone, its best to let huawei staff help you to do the battery replacement instead of a 3rd party vendor. The water proofing will be affected the moment it gets opened up since it will be man made instead of factory machine handled.
By right battery replacement is FOC within the 2 years warranty, but since you've mentioned your usage is 2 years already, most likely need to pay for it.
+1 EDMWER app
Take note the rollout plan for HarmonyOS mentioned above is only for China models. Global model may be totally different, especially for models with Google GMS like the P20/P30.
yhw22
So far got people for P40 series with GMS installed with HarmonyOS is not affecting the GMS feature.
That is a different thing. P40 global version does not come with GMS, so Huawei has no issues to push HarmonyOS updates. For P40 users GMS is installed by the user and it is not Huawei's responsibility even if the GMS is rendered useless. Future upgrade of HarmonyOS may well render P40 GMS hack not working anyway.
For P20/P30 global version users the situation is totally different. GMS is part of the FW. So Huawei will have to be careful. But it could be an opt-in type of upgrades with the warning that GMS may no longer work.
