Huawei P30
Which P30 series color would you get?
  • Breathing Crystal
    Votes: 219 54.2%
  • Aurora
    Votes: 120 29.7%
  • Black
    Votes: 65 16.1%
  • Total voters
    404
vofzxy
Hi my alarm is set to ring daily 8am, anyone knows how to off the alarm for a day (tml) without disabling the whole alarm schedule? Xiaomi is able to do it but I can't find this function in huawei
Sent from HUAWEI P30 LITE using GAGT
you can just turn it off
if you leave the repeat function on,
when you turn it back on, it will still ring repeatedly daily at the stipulated time
keithlin
any one encounter this notification sound issue? i think after the update the sound becomes softer than before..
tjrong07
have you tried tapping the scanner with the top part of your p30? i think that's where the NFC sensor is located cos i did encounter the same issue previously whenever i tapped with the mid section of the phone coming into contact with the scanner. This issue went away when i tap with the top section of my phone and it was able to scan without any error message.
Yes I tried at all kinds of angle but it doesn't work as well. Guess I will have to send it in for servicing for them to check.
stylechap
Yup I know can turn the whole alarm off, just afraid that I forget to turn it back on again.. Xiaomi has the function to snooze it for a day
Try to Power off your phone before you sleep
Before you "Touch to power off"
Should have option to disable alarm for upcoming one below
1982-1994
Any ex iphone users converted to P30 pro? any comments?
Not a P30Pro user but the big difference is definitely the battery life and the screen estate.
iPhone - charge once/twice daily.
P30 pro - charge once every 2 or 3 days.
tjrong07
I'm charging it once a day, the battery drain seem to be quite fast. Is there any way to check what's the capacity of current battery? Am wondering now if my set is refurbished...
skinergy
Samsung user to Huawei P30 user, never realised that the microsd card is Huawei Nano memory....any idea whats the fastest way to transfer my microsd cards (quite a few) quickly into the nano memory or phone?
Sorry noob question, but there's no way to 'modify' the microsd into nano memory right?
1982-1994
https://www.makeuseof.com/tag/monitor-android-battery-health/
Can show your battery usage graph?
1982-1994
Not a techie here but how about the traditional way via computer? Quite a few microsd card means total storage more than 200gb? Very, very slow process.
amelia80
guys to u all think my images look ok?
hi guys i am not sure where i am getting it wrong. this is the default camera mode using the 10mp camera mode and 4:3 ratio. below are the images captured. colors looks strange and clarity i think just about so so .
can i have an honest opinion and also guide me alittle if i need to tweak some camera settings?
i really thought to myself my s9 produced sharper images. =(
TIA!
Jinjia Stupid Idiot
TIA!
Turn off master AI
cokiee
On the p30 pro, how does one save photos sent via WhatsApp without editing if you disabled the auto save?
aw1007
File manager-internal storage-watsapp-media-watsapp images-private.
Sent from HUAWEI VOG-L29 using GAGT
