Huawei P30
Which P30 series color would you get?
  • Breathing Crystal
    Votes: 219 54.2%
  • Aurora
    Votes: 120 29.7%
  • Black
    Votes: 65 16.1%
  • Total voters
    404
vofzxy
portrait mode
normal camera
so yellowish =/
tjrong07
Not sure if any of you experienced similar issue before, but I think my NFC function is cranky.
Previously I was able to use Singtel Dash to make payments via paywave; but recently it doesn't do anything when I tapped/scanned (yes, NFC function is switched on).
Decided to try Google Pay to see if it is the Singtel Dash app problem, but my Google Pay didn't work as well (previously it did work). It kept showing error message of "Phone moved too fast" (which obviously isn't the case as I held the phone there stationary).
Brought it down to HW centre, but they said need to bring it inhouse to check (which I haven't done since I have yet to backup my data).
Just curious if anyone has similar issues before (whether on P30p or other android phones) ?
samsungXP
why i long press my home screen no respone ? i cant add any widget
Sent from HUAWEI P30 Aurora using GAGT
i find the answer.after new update no more long press but need pinch the home screen
Forcecore
Anyone feel that the Bluetooth sound is slight softer than the previous version? Previously when it is around 2/3 I felt the sound was just nice but now i have to press all the way up? Not sure if I'm the only one feeling this way.
Yea I having the same issue the sound on Bluetooth is really soft now compare to previous version.
Beh-Hawk
I have the same issue as well, the Bluetooth sound is way too soft after this update.
I also kanna this issue. Using samsung galaxy buds.
im experiencing the same for bluetooth earphones too. bloody sucks
whencatsruletheworld
I'm not sure if this helps but I was experiencing super low volume for Bluetooth headset.
Until I realized that the volume control is independent. I have to max out the volume on my Jabra Elite 65T first THEN control the volume on my phone regularly.
Try adjusting the volume from your Bluetooth device itself and then from the phone.
Beh-Hawk
hi, how do u do that? all i see here is the main volume control in my phone. tia!
kklau00
Prior to this update, the phone adjusts the master volume on Bluetooth device at the same time. I got issue of either volume too loud or too low.
azarel
have you tried tapping the scanner with the top part of your p30? i think that's where the NFC sensor is located cos i did encounter the same issue previously whenever i tapped with the mid section of the phone coming into contact with the scanner. This issue went away when i tap with the top section of my phone and it was able to scan without any error message.
