Huawei P30
Which P30 series color would you get?
  • Breathing Crystal
    Votes: 219 54.2%
  • Aurora
    Votes: 120 29.7%
  • Black
    Votes: 65 16.1%
  • Total voters
    404
1982-1994
Circle life user. Circle life uses m1 line?
Nothing suspicious on battery usage.
How much does yr p30 drain overnight?
I'm using mate 20 X.
Yeah they are sharing the same infrastructure. I think M1 does not support fast dormancy and hence the draining.the Android OS was always on top under battery usage, upon the phone on standby. Been with them for 8 years
before I port to singtel, because of such problem.
1982-1994
Do you have other SIM card? You can try replacing your current SIM card with singtel/starhub before you go to sleep. To test on the draining.
lighter
how do you change the shortcut icon in the default browser? Try to delete or add but cant find how to do it?
Trent_83
P30... Anyone has the alarm logo reflected even when no alarm is set?
Didn't have this issue previously... Once restart phone it disappear
yhw22
It also happened on my Sony XZ Premium too. Not sure is it the clock app bug.
The alarm is set at Sun 00.00?
Sent from HUAWEI COR-L29 using GAGT
DeadlySkullz
https://youtu.be/ScTqReUbnoY
My phone woke up twice at night. Even thou I have DND activated. 92% down to 88%
Doesn't matter, can try on that but not both at the same time.
Just saw your video, just uninstall/disable apps that you're not using. For me, I uninstall health which I reckon it is the reason for the unnecessary drain in your case.
Though WiFi and Bluetooth do not drain much battery, I don't get it why do users tend to leave it on during sleep.
DeadlySkullz
I will try to uninstall health app and disable Gmail first.
1982-1994
Yeah do it and you'll see improvement.
Anyway how many % did the battery drop before you switched the card?
samsungXP
carousell ppl offer me 650 for my 2 month used P30.still not decide want to sell or not
Sent from HUAWEI P30 Aurora using GAGT
