Huawei P40 Series
pawn_king
Already tried many method. Mine emui is 10.1
All stuck at the Google assistant. Can't even see activate button.
With data and app cloned from my old Huawei phone, I only need grab, gojek, drive works. The rest works good.
Will try a few more methods. If failed, anybody wanted to buy it PM me.
can try those carousell who charge $30-$40.
yhw22
Just resolved on login issue to Google account. You may look for Oscar Debugger from FB or Carousell.
Sent from HUAWEI VOG-L29 using GAGT
yhw22
Just to check with u all, those side loaded last month or before is using Island apk method?
only_lonely
I got. 158 fw then manage to downgrade to. 131 using hisuite proxy and hisuite.
Then followed guide from xda dev now gms loaded with multiple Google accounts. Gmail, gdrive, grab, gojek. WhatsApp restored data all works well. Finally can officially use the phone.
Yuripa
Nice.
Enjoy your new phone :)
Posted from PCWX using GAGT
botak siak
Did you upgrade back to 158????
botak siak
No. The guide mentioned off the auto update. So I suppose not to update it.
Ok roger....didnt get any update even after checking for new update in system settings...seems weird...as im on fw 131....
Btw did you manage to get singpass app to work???
only_lonely
Singpass mobile does not get thru after setting pass code. Error.
But doesn't matter I think. Can use Web version.
I found that ocbc mobile app notification to approve one token isn't work.
So far DBS app the best that appear in app gallery and works good.
botak siak
for those able to sideload GSM, so far any issue?
No major issue so far.... Apart from singpass mobile not working... Some mention tat ibanking apps not wokiring not sure which bank also google pay(not using)... But for me posb ibanking working fine... Netflix not found on playstore but install from aurora store... Gmail getting notification some mention not getting any notification....
Came from fw 158 downgrade to 131...and i think im stuck on 131 as there is no avail update from setting software update....
tanby1413
Loaded with fw 142 later upgraded to fw 158. So far no major issue too. DBS apps ok. Singpass not ok. UOB apps always shown "We are unable to receive your confirmation" when sign in. Need generate OTP from P40 pro Might Secure and enter manually.
