How did you get it with 32gb sd card at $509? The $100 coupon is minimum spend $600.
the hero5 price is $590. then add 32gb card +$29 = 619
then apply qoo10 discount $100 and shop discount $10 = $509
https://havecamerawilltravel.com/photographer/best-memory-cards-gopro-hero5Hi all,
May I know what brands of memory cards should I use on the GoPro Hero 5? And which reputable retailer/online sellers should I get it from? Eg. Warranty and authenticity
Many thanks for taking the time to reply.Much appreciated. Apologies if it's the wrong place to post this question.
Hi all,
Does GoPro honor the warranty if purchase from qoo10?
yeah yeah! totally awesome. ordered mine on Thursday using the coupon!![]()
you can buy the cheapest one u can find on carousell, qoo10, lazada, sls etc..
Where to get extra battery for hero 5 black? Can't find it anywhere.
Walk into Parisilk to buy, call first. I think their price is slightly less than official $599. Alternatively, wait for coupon like some forumers to buy from Qoo10, Parisilk also has an online account at Qoo10 but you have to wait a few working days. I bought mine walking in to Parisilk as I need it urgently.
For microSD card, the max supported is 128GB. The 2 brands you can consider buying locally are Sandisk and Samsung. For Sandisk, I would suggest the 128GB Extreme which has writing speed of 60MB/s. The 64GB variant will have slower writing speed of 40MB/s which is still very usable. If you feel more loaded you can get the Extreme Plus and Extreme Pro from sandisk. As for Samsung, only get their Pro Plus version as the lower range of Evo Plus and Evo Select have slow writing speed of 20MB/s. Just go to Cybermind, Best Bargain or Blizgram in Sim Lim to buy. Or you can go to Challenger to buy as well if that makes you feel safer.
I am using the 64GB Samsung Pro Plus 95 read 80 write speed bought 2 years ago and is working fine. I also have lower rated Samsung and Kingston which also worked quite ok.
I am looking for someone to share if 256GB cards work on the Hero 5 coz I am getting 1-2 from Amazon during the Black Friday sales![]()
