HWZ GoPro users
Extremme
Guys, am new to action camera hence trying to buy a 2nd hand one. Is it a good buy if someone is selling me a gopro hero 5 black bought early this year at 300? The only thing is the cable is missing. Can any USB-C cable charge gopro hero 5? Thks.
Given a choice, would you prefer a 2nd hand gopro 5 with everything but no box or no charging cable?
Anything_Whatever
GoPro 7 coming soon...
Price for GoPro 6 Black may drop....
guile
If you want a Hero 5, get a 2nd hand Hero 2018 instead and do the firmware crack to Hero 5.
They are basically the same hardware, the Hero 2018 is just crippled via firmware. You can find some selling at Carousell.
hellhole
u koe how to do? have you done it?
Anything_Whatever
If your Budget is around $300/-.... suggest you wait for Qoo10’s 10.10 sale or Black Friday sale
Might be able to get BNIB Hero 5 for around your Budget.
For now, Brand new Hero 5 is going @ $350/-
frotle009
Intend to buy gopro hero 2018. Does it comes with a selfie stick?
Not sure if want to buy Hero 7 white instead, but heard it comes with the same specs and built in battery.
nwh_sg
disadvantage of built-in battery is when the battery dies, your gopro also dies. troublesome to rma.
Hero 7 White has no gps too.
One thing going for the new Hero is probably its audio quality. From review, the 7 Black (not sure about White but I guess it should be the same) has much better audio compared to Hero 6/Hero 5.
diwi66
Hi all,
i am interested to get the new gopro hero 7 black.
I saw on gopro that they are selling for $595.
But i saw on carousell there are some sellers taking in pre-orders and price is cheaper than gopro itself. like $525-$550?
How come they can sell cheaper than gopro website?
I am just curious, does anyone knows why?
Anything_Whatever
Hi all,
$595/- is local set with local warranty by official distributor.
Those carousel sellers are parallel importers, bought in from other countries....
May not have warranty (so relying on international warranty) or limited shop warranty.
So you have to consider whether the price difference is worth paying for...
cloudangel
Sian.... just bought the Hero 6 Black awhile black then now come out hero 7 already -_-
Don't much of a different but the improved stabilization seems pretty neat
yusoffb01
go pro 6 stabilization jerks around too much.
Extremme
Guys quick question abt charging. I am charging my hero 5 directly from the camera itself but I realise that after charging for a while, the charging icon (lightning) will be changed to the USB connection icon (plug). Question is, is the battery still being charged.
Anything_Whatever
During charging there are red light indicator..
Once full charge, the red light will go off.... thus the icon change from lightning to cable plug symbol (that one is not USB symbol)
What is puzzling is the screen should be off.... did you set the screen to Always On ?
It will drain the battery very fast.
Extremme
I was monitoring it the whole time yesterday. The battery was not full yet but it was still charging when the cable plug icon appeared and its not 100% yet. And yes I think my display is set to always on. Will change it
Anything_Whatever
It should be fully charged and on standby mode....
If battery juice drop to 95~98%, it will auto charge up again (meaning lightning icon and red light should come on again).
Take note a fully charged battery starts to drain very slowly even though you are not using the GoPro cam... reason could be some features are turn on at standby ready mode (eg. remote voice command, Bluetooth etc.)
Mine is GoPro 6 and it’s is behaving like that....
nwh_sg
I disabled those bluetooth, voice command features.
If not using the gopro, remove the battery.
Before use, charge the battery fully, plug the gopro to computer for it to auto update the date/time (or you update it manually).
