HWZ GoPro users
goldnut
About the same price as the GPH7B
Mine keeps on freezing when it's *not* recording :s22:
android
Hi,
My Gopro hero6 is unable to turn on now even if I take out the sdcard, battery and plug to direct power..anybody has advice where I can get it fixed?
Anything_Whatever
Hi,
You are supposed to leave the battery inside. No battery means no power.
Don’t think GoPro is designed to operate with direct electricity power without battery.
Plug in and leave it to charge for about 30minutes before turning it ON.
Suspect your battery is completely flat.
hacktic
rubber coating on the Gopro camera itself?
maybe u should just get a cheap silicon cover to "wrap" the GoPro up.
yusoffb01
that happens due to high humidity in sg. next time keep in dry cabinet
yusoffb01
Hi,
if cannot on with external power means something dead inside. time to get a cheaper action camera
android
Hi,
Anything_Whatever
Hi,
We dunno where you buy your GoPro from.... so cannot advise you.
If you can contact the seller where you have bought the GoPro, then I think he/she will be able to help you.
