i3-3220 max temperature
tony_ong
Hi all,
just gotten the i3-3220 DIY system for my uncle, now running prime95 test on it. It is running for about 45mins now and the max temperature is at 72c and most of the time hovering at around 64-68 with the processor on 100% load.
Is the temperature ok for this chip?
edit: idle temp is at around 40-45c
Thanks.
tuckloong
Hi all,
Thanks.
yes 60 plus under load and 40 plus idle is fine for the chip :) if it goes a lot higher...can apply new thermal grease and clean the hsf :)
