i5960x Overclock help
wideCDMA
anyone can push i5960x further ?
is 1.25 too high ?
maylyn
~ Rule of thumb ~
In our testing to date, the average overclocked frequency for 5960X processors is 4.5GHz. Very good processors will achieve 4.6GHz fully stable with less than 1.30Vcore. Lesser samples achieve 4.4GHz with the same voltage:
CPU | Frequency | Voltage
5960X | 4.6GHz | 1.30V = Good Result
5960X | 4.5GHz | 1.30V = Average Result
5960X | 4.4GHz | 1.30V = Fair Result
Most of the i7 5960X can do 4.5GHz @ average 1.25V, it's the beyond 4.5GHz that requires sweet spotting.
wideCDMA
~ Rule of thumb ~
hmm mine actually can go to 4.6 at 1.3 :s8:
i think i will stick at 4.5, hope my pc can last for more than 3 years.
maylyn
Good for you ;) Next step is getting 4.6GHz under 1.30V :D
This requires KungFu, everything comes into play (adaptive voltage/offset and others) :s22: ~ overvolt KungFu for the calling :D
Best part of is not getting BSOD124 and other BSOD code (sorry i can't remember which already ~ getting old these days) @ stress full but getting them @ desktop idle lol.
ondooy
all your stuff from amazon ? why not post all of them ?
[DIY] Full Amazon Build... :s13:
wideCDMA
all except for Mainboard and CPU.. thanks for your help also, otherwise i might only build 4790k system..
i decided to go 5960x instead of 5820k, hope i made the right choice... :s12:
wideCDMA
wah ... so yours 4.6Ghz under 1.30v ? :D
ondooy
yup, good choice... ;)
ondooy
why not put the psu fan down ? your case got filter so no need to worry on dust.
make sure to enable evga's eco mode...
maylyn
Err .... if price/performance ratio matters, perhaps you should have gotten the 5820k instead or not planning to SLI/PCIe HHHL or 2-way SLI only etc.
Since it's doesn't matter now :s13: Welcome to the 5960X family :D
Next hoot? Get the Intel 750 HHHL SSD :D
wideCDMA
I am doing Video editing and lightroom photoshop.... i need more processors :D
one GTX 980 maybe overkill for me. for now hehehe..
i love the Intel 750 SSD but 1.2TB too expensive... and 400gb version too slow :(
see how long i can wait for sm951 nvme....
maylyn
Do a push-pull fan configuration on your H110 if you are not, there will be further reduction in CPU temps ;)
