iBasso DX100 Reference DAP Impression
darkarn
Just wondering, can the DX100 work as an USB DAC for your PC/laptop?
BmiamiHK
dx100
Don't know if I'm willin to carry it around. 3x iPhone seems very big :/
Well I am in Hong Kong where it is 34 degrees Celcius and I am carrying the DX100 in my pocket for my 3 hr daily walks to and from work.
atlarge
Anyone know how I can use pandora on dx100?
Can't seem to set up VPN on it.
anyone?
hope someone with experience with the player can assist me in setting up pandora because i have an acct with them and i'd like to have the option to be able to listen to it on the dx100 when i am in a location with wifi.
Thanks!
TeamStereo
Suspended
Haven't tried Pandora because I seldom use the radio =) Will try for you though on mine
simonyeo53
Ibasso DX100 play time
Bro, no need to quote the whole impression lah =:p
I play only lossless files consisting of 16/44.1 and 24/96-192 FLAC and ALAC and I get around 7 hours +- of playing time.
Hi Randius
Sorry to ask you, you get 7 hours +- of playing time, how many percent it left in the battery icon. Whily playing music where you place your DX100 player. because my DX100 only 4 hours +. Thank you.
TeamStereo
Suspended
My personal set goes around 5-7 hours what gain are you normally on? I throw them in my trusty Crumpler bag just nice for DX100, bought at ION Crumpler that time
Randius
Hi Randius
play until flat lor :s13:
I put it on top of table and in air-conditioned room
simonyeo53
Hi
Did you play till Flat (0%)
I play at some time low some time mid, volume at 190-200.
By the way how much you pay for Crumpler bag and which floor it located.
Thank you.:s22::s22:
TeamStereo
Suspended
20-30% (5-6 hours of usage) and the volume is below 180.
Should be slightly below $50 at ION basement 3
Randius
Hi
forgot to mention that I played at mid-gain all the time and volume only about 160-170.
btw, I already sold my DX100
wind30
I just ran my DX100 to test the battery life. 5 hours still have around 30% left. So it should be around 7 hours..
high gain, volume at 180.
wind30
guys.
I stopped the music on the DX100 and turned off the screen by pressing the side button. Left it over night and it drained 30% of the battery...
Is this normal? kind of excessive as I cannot leave it on standby as I will get a flat battery after one day.
how do you "standby" your DX100?
TeamStereo
Suspended
Don't think there is a way but did you check the battery status to see what is draining the battery?
wind30
I have system panel on but I don't see the CPU being active at all. It just seems that the battery is discharging.
Is this normal? Does this happens on the DX100 in Stereo?
