Im using L210 since 2013. Print all notes in color almost every day using third party inks ($12 for 4 CYMK 100ml bottles). Never had ink pad full. Maybe he is confused
if low usage, will get bad clogging or not ? ink dry up ?
if low usage, will get bad clogging or not ? ink dry up ? the L210 can roughly print how many black pages with a full tank ?
leaning towards Canon because using their printers all along, familiarity preference. not sure whether to change brand or not ?
U hear ppl say use third party inks get clog. Well i never used any original inks after it ran out, and still works fine. Could be because i use dye instead of pigment
Canon quote 2000 pages. In practice around 1000 before need to topup. The longest i didnt print was 3months and no clog
If clog does happen, ink tank printers have ink flushing. Use 5% of your ink to remove clog. So its not a problem for dedicated printers.
If u only print black get laser.
1000 pages ? Canon G2000 claims 6000 pages and Epson L210 claims 4000 pages. there's a big difference between advertising and practice.
I have the epson l655, yea need to print regularly to prevent clogging
erm does anyone know if the new Canon authentic ink bottles be used with other models of canon printer? Like other older Canon printer but modded with CISS / modded cartridges?
